Tymphany XT25BG60-04 1" Shielded Dual Ring Radiator Tweeter
Brand:|Model: XT25BG60-04|Part # 264-1012
The Tymphany (formerly Vifa) XT25BG60-04 features a patented dual concentric diaphragm and a unique waveguide center plug that provide an excellent on- and off-axis response.
Regular Price$35.35
Sale Price
$32.00
Part # 264-1012
  • Outstanding performance in 2-way systems
  • Dual ring radiator diaphragm (patented)
  • Waveguide center plug (patented)
  • Copper-clad aluminum VC wire
  • Double magnet system
  • Flat response well beyond 20 kHz
  • Low distortion
The Tymphany XT25BG60-04 features a patented dual concentric diaphragm and a unique waveguide center plug that provide an excellent on- and off-axis response. The XT25-type tweeter is acclaimed for its very natural sound with an extremely smooth frequency response extending well beyond the human hearing range. The dual chamber design and absence of ferrofluid results in a low resonance frequency.
  • Tweeter TypeSoft Dome
  • Cone / Dome Diameter1"
  • Impedance4 ohms
  • Power Handling (RMS)90 Watts
  • Frequency Response1,500 to 40,000 Hz
  • Sensitivity92.4 dB 1W/1m
  • Resonant Frequency (Fs)630 Hz
  • DC Resistance (Re)2.90 ohms
  • Overall Outside Diameter4.09"
  • Cutout Diameter2.83"
  • Depth2.17"
  • BrandPeerless by Tymphany
  • ModelXT25BG60-04
  • Part Number264-1012
  • UPC844632083679
  • Product CategoryTweeters
    (12 Reviews)
  • Weight1.7 lbs.
View similar products to the Tymphany XT25BG60-04 1" Shielded Dual Ring Radiator Tweeter
in the Tweeters product category.
Tymphany XT25BG60-04 1" Shielded Dual Ring Radiator Tweeter is rated 4.8333 out of 5 by 12.
Rated 5 out of 5 by from Natural, Extended but directionalI use these tweeters because they were on sale, not so much for the shielding, but they should sound identical to the unshielded XT25. Anyway, the point is, the author who couldn't listen to music must have flubbed the crossover. OmniMic + XSim FTW! :DThe tweeters matched very well with my side speakers that use german AMT tweeters. The frequency response is no lie at all, but distortion is high at 2kHz, so I wouldn't cross them any lower than that.The first speaker I have used this tweeter in center channel, which is below ear level. I had really hoped I could keep them pointed straight ahead but the tweeters are more directional than I expected. Still very much worthwhile compromise for a great bargain and high value tweeter, and I don't want to over-state the directional nature. Once tilted, I didn't feel I had to keep my head in a vice or anything, or that I couldn't switch chairs. Just at about 25-30 degrees it was too much.
Date published: 2016-03-08
Rated 5 out of 5 by from Nice tweeter. use it in my S10..this tweeter sounds great. i have these with sundown neopro 10s and they keep up. smooth and not fatiguing at all for how loud they get.. have around 70 watts or so going to them. you can cross these real low, but i have them kinda high since i play them loud...
Date published: 2013-04-08
Rated 5 out of 5 by from Excellent tweeter!!!I used these to replace my blown Infinity EMIT-R tweeters. Out of the box they blew my mids out of the water, but after adjusting the crossover they sound Great!! I am crossing them at 4500 hz. I haven't had a marathon listening session in a while, with these tweets I was up all night. Made the old Infinity's come to life. Very nice job Vifa!!
Date published: 2012-11-24
Rated 5 out of 5 by from Great tweeterI have a pair of Royd Heralds that use a 5" woofer and an 18mm modded Vifa tweeter. The highs have always seemed a bit brassy and I found them somewhat fatiguing after extended listening. Replacing the original tweeter with the XT25 has been a revelation.I run them active, crossed at 3500hz.
Date published: 2012-06-29
Rated 4 out of 5 by from Tame this mustang for a good rideI used this tweeter in a small bookshelf two way. Sounded harsh and loud at first . Played around with the crossover and reversed the leads on the tweeter and .. ta da ! It came to life ! Balanced sound without being harsh or overbearing . So far I've ran it up to about 20 watts and was pleased it maintained civility . I managed to build a small 2 way bookshelf system that doesn't need a sub using this tweeter . I'm a happy camper .
Date published: 2012-03-06
Rated 5 out of 5 by from An Absolute Steal!To me it’s hard to understand the review “Good & Bad” - “I couldn't enjoy music with this tweeter. To my ears it was fatiguing in the highs, it was overly smooth in its lower registers, it was hard to get it to blend properly with my 6-1/2" woofer because of the high crossover point”.To me this Tweeter is an UBELIEVABLE value, to my ears completely accurate and not at all fatiguing. I find that it reveals nuances in the high registers that are simply not available with other tweeters, almost at any cost. However, I must point out that the crossover design is critical – use only the finest capacitors and non- inductive resistors – and don’t forget about the wire. 2500 kHz is a good point to begin at, but make sure you don’t have any sag before that. Also eliminating HF interferences from the mids with the crossover is critical – if you look at manufacturer response curves you will often see that while not specifying frequencies above its usable range many drivers have wildly erratic HF peaks above 10K. This WILL create nasty interferences that will be unpleasant to the ear.Of course all this being said – let’s not forget about room acoustics – bordering walls etc., not to mention perhaps the most important thing of all - the recording itself. I find that most rock music is not particularly well engineered. If you want to try some music that is flawless may I recommend Morph the Cat, by Donald Fagen. He loves to “play around” in the high registers with small triangles and other miniature percussion instruments that produce very ethereal sounds.In practice I have been able to design crossovers that provide almost ideal amplitude normalized and phase response with several mid-bass drivers. The included photo shows an unfinished parabolic MTM design using the XT25BG60-04 and two Dayton RS180 -8s along with the corresponding response curves. You can also see the rear of the XT25 through the port at the rear.
Date published: 2012-01-30
  • 2016-05-05T06:27CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_12
  • loc_en_US, sid_264-1012, PRD, sort_mostRecent
I'm looking for a nice tweeter for a bathroom enviroment.... would this be considered waterproof-enough or should I keep searching? I have also been looking at the TB 25-1744S or the 25-1719S... any recommendations?
Asked by: skaterdude50
This should hold up as well as anything in that environment. You may get a little longer use out of a mylar dome but I would expect the moisture would get to the coil before it would effect the dome itself.
Answered by: Chrisf
Date published: 2016-03-09
I'm planning on buying this tweeter and crossing it over at 1800 Hz since that is where my crossover point Is designed at. Will this tweeter give me good sound crossed over at that point?
Asked by: JCsound
Actually this is not a great choice for a crossover point that low. I would recommend something like the Dayton RS28A or RS28F instead.
Date published: 2016-02-11
Good day! How to make this tweeter "Tymphany XT25BG60-04 or Tymphany XT25TG30-04" 4ohms as 8ohms? Thank you in advance for your reply. Regards,
Asked by: Sanny
Unfortunately there is no way to change the impedance of a tweeter like this.
Date published: 2015-08-20
If the face plate is removed what is the dimensions of the driver that is left?
Asked by: George 4
Without the plate the Driver is 72mm ( 2.8") wide x 55mm (2.1") deep
Answered by: TomI
Date published: 2015-03-10
Hi. What is the difference between the XT25TG30-04 and the XT25BG60-04? Is it just that one is shielded? Thanks
Asked by: jeremy7777
The Xt25BG60-04 utilizes a double magnet system. This unit is deeper than the other and the resonant frequency is 100hz Higher.
Answered by: TomI
Date published: 2014-12-16
I have some 3 way speakers with dual 8" woofers, and 5" mid. Highs are crossed over at 5k, and the speakers claim 91db efficiency. Would these overpower everything else? Looking for something that sounds clean, natural, non fatiguing, good off axis.
Asked by: jpsyoda
If the sensitivity number is accurate on the speakers this will be a little bright by comparison. Chances are the number is inflated a bit, so the tweeter might need some padding anyway. This will ultimately be determined by listening tests.
Date published: 2014-11-12
  • 2016-05-04T07:08CST
  • bvseo_cps, prod_bvqa, vn_cps_3.2.0
  • co_hasquestionsanswers, tq_10
  • loc_en_US, sid_264-1012, PRD, sort_recentQuestionsFirst
