264-1126_ALT_0
264-1126_ALT_1
Tymphany TC6FD00-04 2" Full Range Paper Cone Woofer 4 Ohm
Brand:| Model: TC6FD00-04
Tymphany's (formerly Vifa) well-engineered yet economical TC6FD00-04 2" full-range speaker provides accurate, non-fatiguing audio reproduction.
  • Cost-effective ceramic ferrite magnet and stamped steel frame
  • Patented NRSC PentaCut cone technology controls resonances and improves performance
  • Under-spider venting increases power handling
  • Half-roll rubber surround for unrestricted travel
  • Copper pole piece cap controls impedance and extends HF response
264-1126
Weight: 0.4 lbs.
IN STOCK
List Price$14.99
You Save37%
$9.50
Buy 4-up$8.95
Part # 264-1126
Tymphany's TC6FD00-04 brings classic hi-fi capabilities to compact music and media systems. Tymphany's patented PentaCut paper cone technology improves musicality and accuracy, and the driver features a cost-effective ceramic ferrite magnet. A copper cap on the pole piece controls system impedance, thereby extending the upper frequency range.
The TC6FD00-04 is ideally suited for use in flat panel televisions and sound bars, MP3 and cell phone docking stations, hi-fi speaker line arrays, and multimedia PCs.
  • Nominal Diameter2"
  • Power Handling (RMS)15 Watts
  • Power Handling (max)30 Watts
  • Impedance4 ohms
  • Frequency Response150 to 20,000 Hz
  • Sensitivity81.5 dB 1W/1m
  • Voice Coil Diameter0.75"
  • Resonant Frequency (Fs)175 Hz
  • DC Resistance (Re)3.5 ohms
  • Voice Coil Inductance (Le)0.02 mH
  • Mechanical Q (Qms)4.1
  • Electromagnetic Q (Qes)1.29
  • Total Q (Qts)0.98
  • Compliance Equivalent Volume (Vas)0.008 ft.³
  • Mechanical Compliance of Suspension (Cms)0.68 mm/N
  • BL Product (BL)1.92 Tm
  • Diaphragm Mass Inc. Airload (Mms)1.22g
  • Maximum Linear Excursion (Xmax)1 mm
  • Surface Area of Cone (Sd)15.2 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter2.17"
  • Baffle Cutout Diameter1.97"
  • Depth1.37"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3165 Hz
  • Vented Volume0.05 ft.³
  • Vented F3100 Hz
  • BrandTymphany
  • ModelTC6FD00-04
  • Part Number264-1126
  • UPC844632092589
  • Product CategoryWoofers
    (7 Reviews)
  • Weight0.4 lbs.
View similar products to the Tymphany TC6FD00-04 2" Full Range Paper Cone Woofer 4 Ohm
Tymphany TC6FD00-04 2" Full Range Paper Cone Woofer 4 Ohm is rated 4.5714 out of 5 by 7.
Rated 4 out of 5 by from Sounds about right.Played around with them a bit and replaced the drivers of my cheapo PC speakers with these. They sound beter, but of course they need a more proper (larger) enclosure. The ones I stuck them in is barely a litre.
Date published: 2014-11-04
Rated 5 out of 5 by from Amazing little full range!I wanted to build a small table speaker with a mini pam amp (also purchased here). I decided to purchase these drivers due to the other reviews and quite frankly it covers my needs. Decided to build a sealed enclosure with the recommend specs. Parts express shipped FAST and it was well packed too.I bought four and so far used 2. The other 2 are going to a desktop speaker setup using pvc and another small amp.Overall I'm very pleased with the performance of these drivers.
Date published: 2014-07-10
Rated 5 out of 5 by from great for arrays!I recently took 32 of these speakers and made a line array similar to the Kuze 3201- what a sound! Equalization is necessary to flatten out the response on the top end, but otherwise they have a beautiful warm sound, and never get harsh regardless of the power level... I can't wait to get 32 more for the other channel!
Date published: 2014-06-04
Rated 4 out of 5 by from great valueI ordered 2 of these off PE on Amazon.....3 days later a headphone cable showed up???? anyway, I called and they re-sent them out on friday. This is thursday and they just came.I replaced the 2'' drivers on a set of cambridge soundworks satelites. I have them on my wifes computer being powered off a Lepai amp with 2 8'' subs. She loves em. I don't think I could have gotten better sound for 20 bucks.
Date published: 2014-03-07
Rated 5 out of 5 by from Two words... BUY ITI bought one of these to campare with another 2" woofer, the highway bmr12, for aPotential project.But the thing was, THERE WAS NO COMPARISON.This woofer has a completely flat response with an impressive amount of bass.I had it just tapped up into the cardboard box it came in so I could just hear it and mylord! I showed some friends and family members the speaker while playing the song"Let her go" and it sounded like the person was standing right in front of me!It is also effecient as heck, it was filling the room off of just 3 watts!One thing though is that it is so effecient with bass that it pumps a bit too hard, IHIGHELY suggest a sealed box and a crossover at 100hz. I also plugged the specs for this speaker into a special spreadsheet and it showed too that it should only be used in a sealed cabinet, unless you are only useing like 1or2 watts because in that case thebass response would be much better.Prose:efficientSturdyFlat frequencyAmazing soundGood bassCons:Bass sensitive in a bad way tooMagnet darn close to the lip around suround makes hard to mount.
Date published: 2014-02-04
Rated 4 out of 5 by from Excellent as a wide band midrange driverI used this little driver in a recent center channel project along with the flangless Vifa OT19 tweeter and the Dayton RS125-4. I selected it based on the low distortion performance on Zaph's website and it's very low cost. This driver is excellent for the money. I don't think there is any other small driver that has the same kind of low distortion and smooth response anywhere close to this price.I used this driver crossed approximately 2nd order electrical/accoustic at 800hz and 3900hz. The driver is very easy to work with in terms of designing a crossover. I used 4 parts plus a padding resistor and it easily fell into place.What I don't like about this driver, and why I only gave it an average for features, are two things: 1) the frame is not only very flimsy stamped steel, but is also very small. This includes the tabs for the speakers which are also very small and flimsy. 2) The efficiency is pretty low.I used a 2" fostner bit for the cutout with the driver rear mounted and it was a little too big. I would recommend measuring with calipers first. I think 1 15/16" would have been perfect.Overall, despite the issues I have with the frame, this is an excellent performing driver for the price.
Date published: 2013-11-04
  • 2015-04-27T07:25CST
  • co_hasreviews, tv_0, tr_7
  • loc_en_US, sid_264-1126, PRD, sort_mostRecent
1) 15W RMS: Can I power this from aftermarket heatunit (13 Wrms)without HPF?  2) flat response from 150 Hz (sealed box): What if I have just this speaker pair and subwoofer xo 150 HZ? (no door woofer)
Asked by: RLee
In a word, no. You will want a high pass filter on these if you plan on using any more than a few watts.
Date published: 2014-10-07
Which terminal is negative on these? One is marked with a paint dot, the other is not. Thanks!
Asked by: bkirkbri
The terminal that is marked will always be positive.
Date published: 2014-10-27
is the 81.5 dB 1W/1m sensitivity considered loud?
Asked by: speakerfreak1
81.5 is considered quite low on average but typical on a speaker this size.
Date published: 2014-04-21
What type of enclosure for 2 of these in a portable speaker setting
I'm planning on installing 2 of these with the Sure electronics 2x15W amp. How much volume should the enclosure have? And rather a sealed or vented enclosure?Thanks!
Asked by: Luciano
The recommended vented enclosure for two of these is 0.1 cubic feet with two 1" diameter ports that are 2" long each. this will tune the box to 120 Hz.
Date published: 2014-04-19
Placement near phone or MP3 player
I would like to use these in a custom speaker dock for my mobile phone and I was wondering if there is any danger in having such large magnets near my source (phone/mp3 player). Thank you!
Asked by: TenTwelve
Nope, no problem at all with that. All portable electronics are shielded from external magnetic fields by means of metal cases fully surrounding all the sensitive parts of the electronics. Even without this shielding, there would unlikely be any issues, since the magnets in speakers are actually relatively weak. Pretty much the only way you'd have issues with a magnetic field near a portable electronic device would be if it were several times stronger than even the largest speaker magnets, AND if it were varying in intensity at a very high rate, So, you'd need a lab-grade electromagnet running at a high frequency.The only issue you'll run into with a non-shielded speaker such as this one is that it will distort the colors on a CRT TV or monitor. And, if the speaker gets close enough to the CRT, it could permanently damage it. But, you'd have to put it right up against the screen for that to happen, and most likely it would only happen with the less-common aperture grille type CRTs, rather than the more-common shadow-mask types.
Answered by: eboyer
Date published: 2012-10-01
  • 2015-04-27T10:09CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_264-1126, PRD, sort_recentQuestionsFirst
Customer projects that include: Tymphany TC6FD00-04 2" Full Range Paper Cone Woofer 4 Ohm
Discussions in our TechTalk Forum that include: Tymphany TC6FD00-04 2" Full Range Paper Cone Woofer 4 Ohm
