264-1154_ALT_0
264-1154_ALT_1
Tymphany PMT Series 40N25AL01 1-1/2" Aluminum Dome Micro Full Range Speaker 4 Ohm
Brand:| Model: 40N25AL0
The 40N25AL01 1-1/4" aluminum cone full-range driver from Tymphany is purpose-built for television, computer, micro array, and other modern audio applications.
  • Flat, controlled frequency response from 300 Hz to 16,000 Hz
  • Designed for use as a small full-range speaker or for line arrays when used in groups
  • Polymer frame with integrated grill
  • Very low resonant frequency and Qts specifications, especially for a driver this small!
264-1154
Weight: 0.1500 lbs.
IN STOCK
List Price$16.99
You Save25%
$12.74
Buy 4-9 $11.47
Buy 10-up$10.32
Part # 264-1154
The PMT Series family of micro speakers, from Tymphany, is designed for maximum full-range bandwidth, while maintaining superior off-axis response.
Tymphany built the 1-1/4" 40N25AL01 PMT Series premium micro transducer for computer, television, micro array, and similar modern audio applications. It features a neodymium motor, light aluminum cone, and high-temperature polycarbonate frame that is designed for minimum center-to-center mounting distance and reduced comb filtering.
A low 234 Hz resonant frequency allows the 40N25AL01 to reproduce frequencies lower than most drivers this size (250 Hz), while maintaining an average sensitivity of 85.6 dB (2.83V/1m) from 300 to 16,000 Hz. Using four drivers in a series-parallel group of four units increases average sensitivity to a respectable 91 dB (2.83V/1m).
  • Nominal Diameter1-1/2"
  • Power Handling (RMS)2 Watts
  • Power Handling (max)4 Watts
  • Impedance4 ohms
  • Frequency Response234 to 20,000 Hz
  • Sensitivity85.3 dB 2.83V/1m
  • Sensitivity81.8 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)234 Hz
  • DC Resistance (Re)3.6 ohms
  • Voice Coil Inductance (Le)0.05 mH
  • Mechanical Q (Qms)1.9
  • Electromagnetic Q (Qes)0.59
  • Total Q (Qts)0.45
  • Compliance Equivalent Volume (Vas)0.01 ft.³
  • Mechanical Compliance of Suspension (Cms)45.86 mm/N
  • BL Product (BL)3.02 Tm
  • Diaphragm Mass Inc. Airload (Mms)1.01g
  • Maximum Linear Excursion (Xmax)1.90 mm
  • Surface Area of Cone (Sd)8.0 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Basket / Frame MaterialPolymer
  • Magnet MaterialNeodymium
  • Overall Outside Diameter1.6"
  • Baffle Cutout Diameter1.57"
  • Depth0.61"
  • Bolt Circle Diameter1.81"
  • # Mounting Holes4
  • BrandTymphany
  • Model40N25AL0
  • Part Number264-1154
  • UPC848864014920
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
  • Weight0.1500 lbs.
View similar products to the Tymphany PMT Series 40N25AL01 1-1/2" Aluminum Dome Micro Full Range Speaker 4 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
Is this driver open on the back side? I need to know if I need to put it in a separate enclosure like a small midrange driver.
Asked by: SpeakerGuy1971
Yes this driver is open-back.
Date published: 2014-07-15
Customer projects that include: Tymphany PMT Series 40N25AL01 1-1/2" Aluminum Dome Micro Full Range Speaker 4 Ohm
