264-1134_ALT_0
264-1134_ALT_1
Tymphany NE180W-08 6-1/2" Fiber Cone Woofer Speaker
Brand:| Model: NE180W-08
Tymphany's (formerly Vifa) NE180W-08 6-1/2" speaker is an advanced, well-engineered woofer and midbass driver designed for accurate audio reproduction.
  • Cast aluminum frame promotes motor cooling
  • Sculpted design improves airflow and reduces reflections
  • High-strength compact neodymium magnet system
  • Proprietary coated natural wood fiber cone with half-roll rubber surround
  • Long-throw 1-1/2" voice coil on titanium former
  • Copper pole piece cap for extended HF response
  • 8 ohm nominal impedance
264-1134
Weight: 1.95 lbs.
IN STOCK
List Price$161.99
You Save25%
$121.67
Buy 4-up$111.32
Part # 264-1134
The Tymphany NE180W-08 6-1/2" Neodymium Woofer is characterized by the NE Series' cast aluminum basket; an innovative sculpted, open design that minimizes internal acoustic reflections and assists the neodymium motor's thermal management.
A coated natural wood fiber cone with a butyl rubber surround is FEA optimized for linearity of performance. Finite element analysis techniques also contribute to inclusion of the motor's copper cap, which reduces inductance and extends the speaker's upper frequency performance.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)80 Watts
  • Power Handling (max)160 Watts
  • Impedance8 ohms
  • Frequency Response40 to 4,000 Hz
  • Sensitivity87.4 dB 2.83V/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)42 Hz
  • DC Resistance (Re)6.2 ohms
  • Voice Coil Inductance (Le)0.12 mH
  • Mechanical Q (Qms)7.4
  • Electromagnetic Q (Qes)0.41
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)0.8 ft.³
  • Mechanical Compliance of Suspension (Cms)0.86 mm/N
  • BL Product (BL)8.17 Tm
  • Diaphragm Mass Inc. Airload (Mms)16.39g
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)136.9 cm²
  • Cone MaterialWood Fiber
  • Voice Coil FormerTitanium
  • Magnet MaterialNeodymium
  • Overall Outside Diameter7.09"
  • Baffle Cutout Diameter6.18"
  • Depth3.65"
  • # Mounting Holes5
  • Sealed Volume0.24 ft.³
  • Sealed F386 Hz
  • Vented Volume0.58 ft.³
  • Vented F347 Hz
  • BrandTymphany
  • ModelNE180W-08
  • Part Number264-1134
  • UPC844632092619
  • Product CategoryWoofers
    (1 Reviews)
  • Weight1.95 lbs.
View similar products to the Tymphany NE180W-08 6-1/2" Fiber Cone Woofer Speaker
Tymphany NE180W-08 6-1/2" Fiber Cone Woofer Speaker is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from superBest value for money.Sound is amazing.I built a bookshelf for a customer with these woofers and he loved it.
Date published: 2015-01-02
  • 2015-05-27T06:57CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.3
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_264-1134, PRD, sort_mostRecent
suitable tweet?
after reviewing my previous choices for pairing, what would be a comparable high frequency driver that will not break the bank?
Asked by: m.oreilly
It is almost impossible to recommend a tweeter that someone will automatically like. You might consider the Dayton Reference series models, these are an excellent value and are available in both soft or aluminum dome types.
Date published: 2013-10-30
  • 2015-05-27T09:50CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.3
  • loc_en_US, sid_264-1134, PRD, sort_recentQuestionsFirst
Customer projects that include: Tymphany NE180W-08 6-1/2" Fiber Cone Woofer Speaker
