Tymphany LAT250 Linear Array Transducer
Brand:|Part # 299-850
The patented dual-motor LAT 250 is designed to provide strong bass performance in a new vibration-free, cylindrical form factor.
Part # 299-850
  • High-output, compact bass transducer
  • Cylindrical dual-motor design inherently cancels extraneous vibrations
  • Rectangular chassis creates new mounting location opportunities
  • Easily modeled using T/S parameters
The patented dual-motor LAT 250 is designed to provide strong bass performance in a new vibration-free, cylindrical form factor. The driver may be configured for use in sealed, vented, bandpass, or open-baffle enclosures, and provides high bass output from a very compact transducer. In typical applications, the Tymphany LAT 250 has mechanical vibration more than 90% less than comparable loudspeakers, even at full output. Paired with the appropriate high frequency driver, the Tymphany LAT 250 is an ideal solution for lifestyle consumer electronics products such as flat panel TVs and sound bars, MP3 and cell phone docking stations, multimedia PCs, and other small devices. Note: The nominal impedance is calculated with both 4 ohm coils driven in parallel. Tymphany LAT 250
Specifications: • Power handling: 100 watts RMS/200 watts max • Le: 0.27 mH • Impedance: 2 ohms • Re: 2 ohms • Frequency response: 60-1,600 Hz • Fs: 60 Hz • SPL: 84.5 dB 1W/1m • Vas: 0.31 cu. ft. • Qms: 3.4 • Qes: 1.0 • Qts: 0.79 • Xmax: 3 mm • Dimensions: Overall diameter: 10.2" x 3.5", Cutout diameter: 9.4" x 2.7", Depth: 1.35" (half of total diameter).
  • ApplicationLow Frequency Bass Shaker
  • Impedance2 ohms
  • Power Handling (RMS)100 Watts
  • BrandPeerless by Tymphany
  • Part Number299-850
  • UPC844632083082
  • Product CategoryProducts
    (14 Reviews)
  • Weight1.85 lbs.
View similar products to the Tymphany LAT250 Linear Array Transducer
in the Products product category.
