Tymphany D19TD-05 3/4" Poly Dome Tweeter
Brand:|Model: D19TD-05|Part # 264-500
Tymphany's (formerly Vifa) affordable D19TD-05 3/4" poly dome tweeter features good dispersion and excellent power handling. High loss diaphragm. Voice coil is ferro fluid cooled.
List Price$29.99
You Save34%
$19.94
Buy 4+$18.88
Part # 264-500
  • High 80 watt RMS power handling with appropriate crossover
  • Small 3/4" dome for great off-axis response
  • Ferro fluid cooled
Affordable 3/4" poly dome tweeter features good dispersion and excellent power handling. High loss diaphragm. Voice coil is ferro fluid cooled.
  • Tweeter TypePoly / Mylar Dome
  • Cone / Dome Diameter3/4"
  • Impedance8 ohms
  • Power Handling (RMS)80 Watts
  • Frequency Response3,500 to 20,000 Hz
  • Sensitivity89 dB 1W/1m
  • Resonant Frequency (Fs)1,700 Hz
  • DC Resistance (Re)6.20 ohms
  • Overall Outside Diameter3.70"
  • Cutout Diameter2.67"
  • Depth0.90"
  • BrandTymphany
  • ModelD19TD-05
  • Part Number264-500
  • UPC844632020209
  • Product CategoryTweeters
    (49 Reviews)
  • Weight0.6 lbs.
View similar products to the Tymphany D19TD-05 3/4" Poly Dome Tweeter
in the Tweeters product category.
Tymphany D19TD-05 3/4" Poly Dome Tweeter is rated 4.8367 out of 5 by 49.
Rated 5 out of 5 by from Quality speakerWorks good in my model L Ohm speakers . 6.2 ohm reading matched the original low tweeter. It improved the sound of these speakers.
Date published: 2015-12-02
Rated 5 out of 5 by from Nice Replacement TweetersI used these drivers to replace a pair of low-efficiency paper cone tweeters in 1990's bookshelf speakers. Wow! What a difference! Brilliant clarity but without harshness. These speakers do not produce that "ice pick to the ear drum" effect that you might find in some tweeters in this price range. They sound crisp and clear, but at the same time smooth and not fatiguing. (I hope I'm making sense here) At this price, I could not be happier.
Date published: 2015-10-21
Rated 5 out of 5 by from Great Replacement Tweeters for Eosone RSF 1000All 4 of my eosone 1rd0010-1 tweeters were blown and these are exact replacements, even the screw holes matched perfectly. Glad I found them!
Date published: 2015-05-02
Rated 1 out of 5 by from Stopped working after 18 monthsPurchased 2 of the tweeters and one is very defective after 18 months because it makes a scratching sound. The speaker cabinet assembly is not the problem because it has been verified. (eg ohmmeter)
Date published: 2015-03-22
Rated 5 out of 5 by from Vifa Tymphany 3/4 Poly Dome Tweeter D19TD-05After wading through endless reviews of different tweeters and experimenting with other brands, I settled on the Vifa Tymphany and was not disappointed. I have a rather large three way setup with a 12" bass, 8" Fountek mid-bass (superb) - so the tweeters were critical: otherwise the setup would of become bass heavy. Which was not the case nor are they shrill. The tweeters meld in nicely with the other speakers, almost seamless. Delivery to the door in Sydney Australia a couple of days! Very happy.
Date published: 2015-03-09
Rated 5 out of 5 by from AmazingThis tweeter went to the Netherlands, were i build more loudspeakers and this tweeter is able to project the sound very 3d into the room. Excellent !!
Date published: 2015-02-15
  • 2016-02-11T06:36CST
  • co_hasreviews, tv_0, tr_49
  • loc_en_US, sid_264-500, PRD, sort_mostRecent
would this sound good matched with the Goldwood GW-208/8 8" OEM Woofer and crossed over with the 5 kHz High Pass 8 Ohm Crossover? in a 4ft tall by 10 inch wide box? 2-way setup. port or sealed? Yamaha R-S201 Stereo Receiver powering it
Asked by: Brad79
Date published: 2015-09-15
Can a amplifier even see impedance of this HF transducer thru a passive x-over? Single or pairs at such low wattage with such high efficiency might be negligable without a load. I've never considered ohms in such low voltage applications. Repercussions?
Asked by: sailfish
Yes an amp will see a load on a high frequency driver regardless of high pass used, but the load will be very small.
Date published: 2015-08-13
Have a Paradigm Phantom speaker with a blown tweeter. The original model nr. is D19TD-16 and this model is D19TD-05. Will this twitter be a a good replacement?
Asked by: Rovak73
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-07-08
Can this tweeter work with the Dayton 3.5K crossover? or should I use the 4.5K crossover?
Asked by: Unbiasedsound
You would be safer if you went to 4k or higher. The bottom end response of this tweeter is 3500Hz
Answered by: TomI
Date published: 2015-05-12
Can I replace Cerwin Vega dt1860 with these?
Asked by: Jdub14u
Date published: 2015-04-14
Is the D19TD-05 the same thing as a D19TD-27-08? I am trying to find these tweeters for several sets of Paradigm speakers I have have for quite a while. Please advise.
Asked by: Proud Dad
Answered by: MattW
Date published: 2015-04-01
  • 2016-02-11T07:17CST
  • co_hasquestionsanswers, tq_24
  • loc_en_US, sid_264-500, PRD, sort_recentQuestionsFirst
