Tymphany BC25SC55-04 1" Square Frame Tweeter
Brand:|Model: BC25SC55-04|Part # 264-1024
The smooth-sounding BC25 SC55-04 1" compact soft dome tweeter from Tymphany (formerly Vifa) features high output and response past 30 kHz thanks to a high-strength neodymium motor with heatsink fins.
List Price$24.99
You Save35%
$16.25
Buy 4+$14.75
Part # 264-1024
  • Polymer faceplate with recessed waveguide loading
  • 1" treated soft dome
  • Neodymium magnet for high output and compact size
  • Truncated faceplate permits optimal driver spacing
  • Rear heatsink increases thermal management
  • Frequency response extends past 30 kHz
Smooth-sounding compact soft dome tweeter with high output and response past 30 kHz. High-strength neodymium motor with heatsink fins. The truncated faceplate helps this tweeter achieve optimum center-to-center driver placement in many baffle designs.
  • Tweeter TypeSoft Dome
  • Cone / Dome Diameter1"
  • Impedance4 ohms
  • Power Handling (RMS)25 Watts
  • Frequency Response1,320 to 30,000 Hz
  • Sensitivity94 dB 1W/1m
  • Resonant Frequency (Fs)1,320 Hz
  • DC Resistance (Re)3 ohms
  • Mechanical Q (Qms)2.90
  • Electromagnetic Q (Qes)1.70
  • Total Q (Qts)1.10
  • Overall Outside Diameter2.74" x 2.13"
  • Cutout Diameter1.70"
  • Depth1.10"
  • BrandTymphany
  • ModelBC25SC55-04
  • Part Number264-1024
  • UPC844632083730
  • Product CategoryTweeters
    (7 Reviews)
  • Weight0.15 lbs.
View similar products to the Tymphany BC25SC55-04 1" Square Frame Tweeter
in the Tweeters product category.
Tymphany BC25SC55-04 1" Square Frame Tweeter is rated 5.0 out of 5 by 7.
Rated 5 out of 5 by from excellent tweeterThis is an excellent tweeter for bookshelf speakers
Date published: 2014-05-11
Rated 5 out of 5 by from perfect fit and sound!I bought 6 of these to replace tired tweeters in some MK satellites.
Date published: 2014-02-24
Rated 5 out of 5 by from Great for studio monitors too...I bought this over a year ago. I've tested it in a center channel for home audio, and now they are in my new studio monitors I just finished. Even testing it alone, the sound is very nice! You can almost even run it without a crossover because it can handle the power with minimal distortion. I gave it 5 stars because: Price is great. The performance is spectacular. It has a nice magnet with heat dissapating fins which is an innovative design. The tweeter is bright (94db) so I used a good 10 watt non-inductive resistor for my monitors. It has a very clear and precise upper bandpass region too. I highly recommend it. Thanks PE!
Date published: 2012-10-19
Rated 5 out of 5 by from Great, Versatile little tweetersNice compact little tweeters, Great for small to large projects and they're high efficiency allows you to combine them with larger number of different woofers(if they're to bright you can dial them back with a L-PAD) On those compact projects the truncated face plate/horn allows you to mount them up close to the mid/bass drivers where they need to be. I'm using these in a MTM with 5.25" Peerless, 0.5 cu/ft vented boxes, 3500 Hz x-over is a 2nd order Linkwitz-Riley with an impedance EQ circuit on the Vifa BC25SC55's combined with a 1st order Butterworth on mid/bass drivers. "WOW" these are a really good value and can put out alot of crisp, clean sound for the buck. There intended use is computer speakers for my wife. I've also replaced a variety of other tweeters with these little guys and they worked as good or better than the original. You can't beat them for the price. Will be getting a bunch more. Thanks PE
Date published: 2012-10-12
Rated 5 out of 5 by from Very pleased with Vifa woofer and tweeters."the Vifa BC25SC55-04 1" Tweeter is fabulous! Very efficient at 94dB/1W and sounds GREAT!! Got these on sale for $11ea. and used them for a speaker project of mine and am very pleased with them.Also bought pair of Vifa TC9FD-15-08-3-1/2 Full Range Paper Cone Woofer for $4 ea. and they sound incredible for such low price. (what a bargain!)Very happy customer indeed.
Date published: 2012-07-16
Rated 5 out of 5 by from great performance and priceused this on a MTM set up with the Aura 299-030's. Great matchup. Very affordable. went single order X-over. You will enjoy the sound even more as you relate to the low cost of these items. When you're talking about a system with six speakers and crossover components for around $80 bucks, well................ Go PE.
Date published: 2011-12-02
  • 2016-02-09T06:32CST
  • co_hasreviews, tv_0, tr_7
  • loc_en_US, sid_264-1024, PRD, sort_mostRecent
Could somebody send me the mounting hole dimensions? Trying to replace a set of mirage m290 tweeters ( assuming they are 4ohm) which are also square mount tweeters. Just hoping the mounting dimensions are close. Thank you
Asked by: alex s
You can see all mounting dimensions in the spec sheet below.www.parts-express.com/pedocs/specs/264-1024--tymphany-bc25sc55-04-spec-sheet.pdf
Date published: 2015-12-14
Hi, Is this tweeter a good substitute for the Vifa D26NC-55-06?  How do they compare? Regards, David
Asked by: dsmithr
These are two completely different tweeters other than overall appearance. The impedance is different as well as overall size, so these would not work well as a substitute without crossover and cabinet modifications.
Date published: 2015-09-01
Please help me. i buy two tweeters, how can i reach 3500 Hz x-over ? , as they say down. with a capacitor 8uF ?
Asked by: alicia mendez
I would recommend a cap and coil for that crossover point. A cap value of 8 uF and a .25 mH coil will provide a second order high pass filter of 3,500 Hz.
Date published: 2015-09-09
Hi! I thought this was listed as ferrofluid cooled: is it? Thank you for your help!
Asked by: unklvin
Vifa does not mention ferrofluid in any of their documents. This may be something they changed.
Date published: 2015-01-12
I currently have 2 separate speakers wired to each of my speaker terminals of my home theatre amp. I have had it setup like this for years without trouble. Is this a terrible idea? And does this drop to the wattage to each of the speakers?
Asked by: ShaneU
How do you recommend cutting a 1.7" hole? I assume that means a 1 7/10" hole, and not a 1 7/8" hole? Thanks
Asked by: dholt44
Yes this is a 1.7" (7/10) hole. This is just shy of 1.75" and there is plenty of tolerance for a slightly larger opening. You should be able to find a 1.75" hole saw or spade bit to make this easier.
Date published: 2014-08-25
  • 2016-02-09T07:17CST
  • co_hasquestionsanswers, tq_8
  • loc_en_US, sid_264-1024, PRD, sort_recentQuestionsFirst
