300-701_ALT_0
300-701_ALT_1
300-701_ALT_2
300-701_ALT_3
300-701_ALT_4
TriTrix MTM TL Knock-Down CNC Speaker Cabinet Pair
Product Video
These knock-down TriTrix MTM transmission line (TL) cabinets save you time and money. Precision CNC cuts offer accuracy comparable to the craftsmanship of a master woodworker—maybe even better!
300-701
Weight: 70.25 lbs.
IN STOCK
$135.80
Part # 300-701
Qty:  PR
The 3/4" MDF construction utilized by the TriTrix knock-down cabinets ensures maximally damped enclosures to prevent annoying resonances that color the sound. The speaker cabinets ship unassembled, but are simple, quick, and easy to construct by simply following the instructions in the video above. Wood screws included. Sold in pairs.
Tritrix Cabinet Dimensions
Note: Wood glue recommended (not included). Use of wood clamps is also recommended.
  • BrandParts Express
  • Part Number300-701
  • UPC844632078880
  • Product CategoryKnock-Down Speaker Cabinets
  • Unit of MeasurePR
    (17 Reviews)
  • Weight70.25 lbs.
View similar products to the TriTrix MTM TL Knock-Down CNC Speaker Cabinet Pair
in the Knock-Down Speaker Cabinets product category.
TriTrix MTM TL Knock-Down CNC Speaker Cabinet Pair is rated 4.6471 out of 5 by 17.
Rated 4 out of 5 by from Super Easy!I spent more time finishing these then assembling them.  A kid could do it.  I would have given this project 5 stars had the two internal braces for each cabinet not been missing.  It was an easy fix so it did not impact my build.
Date published: 2014-01-16
Rated 4 out of 5 by from these are really clever!i bought these to save time and i modified them slightly. i increased the front baffle, changing it to a top mount and increasing the width. it now each cabinet houses dual peerless HDS 6.5 woofers, a morel em1308 dome mid and a vifa ring radiator tweeter. Custom built xovers and wow!! i finished them with real wood red maple veneer and three coats of stain and 4 coats of highly polished poly. VERY HAPPY WITH THE RESULT! If you have the ability to build an accurate xover system, and the knowledge to play with the internal damping of the box, this is just another way to go with these cabinets. They are a great example of a TL design in compact form. Just a note...make certain you have good clean power. TL designs are often not super efficient, but they make excellent bass that is deep and smooth...but not boomy or thumpy like the heavy bass that a lot of people think bass should be...ie big box car sub systems...home audio and audiophile bass is not quite so thumpy. when selecting a mod option you will have to make some adjustments to the internal folding horn. (not always but sometimes)...to avoid this try and select drivers that will have a comparable f3 and fq range as the dayton drivers originally used when the parameters for this TL enclosure were calculated give or take ....you have a little room +/_ form the original specs, but don't go crazy or you will have to make modifications! TL enclosure calculations can be complicated!
Date published: 2010-12-23
Rated 4 out of 5 by from Clean cutThese cabinets go together really easy. The CNC cut MDF makes for very clean edges. Although, I was dissapointed when I opened the box. After sorting out the different pieces I noticed I was missing 3 of 4 interior supports and given an extra corner bracket that goes in the bottom. Customer service was great and was going to send them right of way. they were just 2" by 6 1/2" pieces of mdf so I made them myself instead of waiting. I think they should have designed them with a few more screws on the sides. Overall they are nice and clean. All the more quick clamps the better!
Date published: 2010-02-19
Rated 5 out of 5 by from too easy!i built a couple pair form scratch as gifts for some close friends, but i was not satisfied with the quality of the material that i used, and the build quality (im not good enough for me!)the fit was great! cleaned up with a router, sanded, and painted piano black. I will keep these!
Date published: 2009-11-01
Rated 5 out of 5 by from Good ProductReally easy to put together. Had to do some sanding on a few rough edges left over, no big deal. Wood screws that came with the kit were aweful so I ended up having to use my own. When I received the kit it did not include speaker screws. This kit it so easy to assemble and sounds so good it makes up for all it's hardware shortcomings.
Date published: 2009-10-07
Rated 5 out of 5 by from A 5 year old can build these!!These cabinets are precisley machined and fit perfect. Transmission line design sounds great. No port noise. Sounds more like bass from a musical instrument than a speaker.
Date published: 2009-08-12
will the tb 5" full range speaker fit in this cabinet?  i know its not recommended but given the cutout for 5 1/4 will Tang Band W5-1611SAF 5" fit?
Asked by: Niel
No, the recesses and through holes would require modification since the Tang Band speaker is just over 6" in diameter, and the Dayton this cabinet is intended for is just under 5-3/4".
Date published: 2014-10-06
Can I use 2 of the TB W5-1611's in each cabinet?
Asked by: Andyld
Unfortunately we do not recommend anything other than the 5-1/4" Dayton Classic woofers in these cabinets.
Date published: 2014-08-12
What is the -3db on the low end of this design? (lower cut off frquency that is)?
Asked by: abear
This design has an F3 of about 48-50 Hz.
Date published: 2014-01-29
Custom made front baffle?
Hi Parts Express Team,Is it possible to order a custom made front baffle for a 2 way design?I am thinking of using a 6.5 Inch FR driver like Fostex and a ribbon tweeter? Will it be a good idea?ThanksVivek
Asked by: viveksaikia
The design works best as designed. You could modify the front baffles to accommodate various speakers. Contact PE to see of they will do it. I would give specs to a local finish carpenter and have the baffles made local and start building a box builder relationship.
Answered by: Nitnub
Date published: 2013-12-15
Is this to be used with two mid/bass drivers in parallel with a two way cross over?
Asked by: Nullo
There are multiple methods possible. Yes your two mid bass drivers would work well as would several other speaker combinations. You could also use a added tweeter and go 3 way.
Answered by: Nitnub
Which Dayton 5 1/4" woofers? And any recommended mid/tweets, xover?
While I appreciate the earlier answer that these enclosures were designed for Dayton 5.25" woofers, I notice that there are several at Parts Express. Would a particular model be optimal? And any recommendations for specific mids/tweeters or crossovers?
Asked by: ZBiscuit
Use speakers that have characteristics you desire.
Answered by: Nitnub
Date published: 2014-10-23
Videos
Customer projects that include: TriTrix MTM TL Knock-Down CNC Speaker Cabinet Pair
