Tripp Lite HT10DBS Home Theater Surge Suppressor
Brand:|Model: HT10DBS|Part # 125-014
Tripp Lite's HT10DBS Isobar Home Theater Surge Suppressor provides up to 3570 joules of surge blocking protection for 10 outlets, 3 coaxial lines, 2 RJ11 jacks (telephone), and 2 RJ45 jacks (Ethernet). $500,000 Ultimate Lifetime Insurance.
List Price$139.20
You Save24%
$105.64
Part # 125-014
  • Provides premium protection (3570 joules)
  • 10 outlets, 3 coaxial lines, 2 RJ11 ports, and 2 RJ45 ports are protected
  • Exclusive Isolated Filter Banks eliminate noise interference between components
  • $500,000 Ultimate Lifetime Insurance coverage with Data Recovery Warranty
Tripp Lite's HT10DBS Isobar Home Theater Surge Suppressor provides premium protection, 3570 joules, stopping damaging surges and filtering disruptive line noise so components perform at their peak. You can see and hear the difference: crisper video; deeper audio and longer component life. Ideal for medium-to-large home theater installations: high-definition TVs, DVRs, satellite and A/V receivers, subwoofers, DVD/CD players and more. Exclusive Isolated Filter Banks eliminate noise interference between components. 10 outlets (with transformer spacing and plug-in safety covers), 3 coaxial lines, 2 RJ11 jacks (telephone/modem), and 2 RJ45 jacks (Ethernet, 100BaseT, high-speed) are protected to safeguard an entire home theater system. $500,000 Ultimate Lifetime Insurance coverage with Data Recovery Warranty (USA and Canada only). Package includes metal power center (with three diagnostic LEDs), color-coordinated outlet/plug labels, 8 ft. cord with a right-angle plug, 6 ft. gold coax cable, 6 ft. phone cord and 6 ft. network cable.
Specifications: • Output capacity: 1440 watts • AC suppression: 3570 joules • AC suppression response time: less than 1 nanosecond • Clamping voltage: 140V RMS • EMI/RFI filtering: up to 60 dB • Dimensions: 14-1/4" L x 2-1/4" W x 3-11/16" D. Certifications: • UL1449 1998 Rev. (AC Suppression) • UL1363 (Power Tap) • UL497A (Communications) • FCC Part 68 (Communications) • Exceeds IEEE 587 category A&B specifications.
  • Number of Outlets10
  • Cord Length8 ft.
  • ColorBlack
  • BrandTripp Lite
  • ModelHT10DBS
  • Part Number125-014
  • UPC037332121745
  • Product CategoryOutlet Strips & Surge Protectors
    (59 Reviews)
  • Weight4.86 lbs.
View similar products to the Tripp Lite HT10DBS Home Theater Surge Suppressor
in the Outlet Strips & Surge Protectors product category.
Tripp Lite HT10DBS Home Theater Surge Suppressor is rated 4.8136 out of 5 by 59.
Rated 5 out of 5 by from I would definitely buy this product again.I purchased this item 7 years ago. The product saved my electronic devices from being destroyed. I called the company and I had a new one within one week to replace it free of charge. The lifetime warranty was a life savior.
Date published: 2015-12-09
Rated 4 out of 5 by from So far so good.This product seems to be made very well. The only reason I didn't give it five stars is that I won't really know if it works until there's an incident.
Date published: 2015-11-06
Rated 4 out of 5 by from Well Made, Heavy duty...I purchased this to replace an old Monster Cable 1100. This unit appears to be the equivalent, if not better version of the Monster. Ample outlets, inputs/outputs. It seems to be very well made and heavy duty. I hope to get at least 10 years out of it like my previous unit. A bit pricy, but seems to be well worth the investment.
Date published: 2015-10-15
Rated 5 out of 5 by from Industrial strength protection for a home theater and moreFortunately, I have not been the victim of a power surge, so this review is based on overall design and usability of the product. I will say that Tripp-Lite's warranty and connected equipment policy are the best in the industry and their customer service is perhaps the best in the industry. In terms of overall design, I continue to be impressed by the thought that went into the HT10DBS. Not only are there widely-spaced outlets for use with transformers, but half the regular outlets face inward and half face outward, in contrast to competing brands, where they all face one direction or the other. This can make a significant difference in devices with large, polarized plugs that only fit one way. Protection is provided for phone lines, ethernet networks and for three coax sources, although I seriously doubt many would have the need to connect cable, satellite and an antenna at the same time. The one and only shortcoming as I see it is the lack of multiple RJ-45 (ethernet) connectors. Also, I cannot find any specs anywhere as to whether these are CAT5 or CAT6 - a critical difference when it comes to speed. The reason this is a shortcoming is that it only provides for protection of one side of ones router - either the WAN port or a single LAN port. Let me explain - the majority of the time, this would not be an issue. Most surge damage is caused by a power spike entering through the power line, with a smaller percentage entering over the phone line or via one's cable or broadband provider. A significant percentage of the time, however, surge damage is caused by a nearby lightening strike creating a surge in an antenna. This need not be a direct strike. For obvious reasons, particular care must therefore be taken to isolate an outdoor antenna, or even an indoor antenna. However routers contain a WiFi antenna that is potentially vulnerable to a nearby lightening strike. No surge protector can protect the router itself from this sort of damage, but surge protection on the LAN side of the router could help prevent the damage from spreading across one's LAN to their other equipment. Granted, a lightening strike close enough to fry a router could potentially induce a damaging surge in the wiring of the rest of one's equipment, but why did Tripp-Lite leave open such an obvious vulnerability? Other than that, this is the best-designed surge protector I've ever owned, and I've owned ones from many different manufacturers. I bought three HT10DBS protectors - one for my home theater setup, one for my computer workstation and one for the spot where I typically plug in my laptop. I've read horror stories of people with multiple brands of surge protectors being left high and dry as the different manufacturers point fingers at each other over who is responsible for damage. Therefore, I have made sure to protect all equipment on my home network with an HT10DBS.
Date published: 2015-03-22
Rated 5 out of 5 by from This product is second to none.I live in the Midwest and my HT10DBS has saved me numerous amount of times. I own 3 of them. They have saved my audio and video to my PC and WI-fi . I have owned them for years and only had one problem with one of them. that was when we had a direct lightning hit out side my home on my farm. it exploded a huge oak tree and took out the phone line in on the tripp lite HT10DBS. "I would love to show the tree but i cant find anywhere to upload a photo" I contacted tripp-lite and told them about the situation and they were very courteous and got me a new one on the way. I highly recommend this product.
Date published: 2015-02-25
Rated 5 out of 5 by from High quality product with excellent featuresAs advertised, and more - This product not only improved the protection level of my home theater system, but also improved the overall picture quality from my (wall) cable source. The design is exceptional, with little wasted space, despite my use of a three-pronged TV cable and 6 additional electronic devices. The extra cable input line and plastic dust covers for the unused outlets were unexpected niceties. The quality, useful design, and level of protection for the price (in addition to the generous warranty) greatly exceeded those of the Monster Power cable it replaced. Thanks Tripp-Lite!
  • 2016-02-08T06:47CST
  • co_hasreviews, tv_0, tr_59
  • loc_en_US, sid_125-014, PRD, sort_mostRecent
