Triplett TSC-MC1 SoniChek MC Mini Sound Lever Meter
Brand:|Model: TSC-MC1|Part # 391-078
The Triplett SoniChek MC is a compact sound level meter with C weighting. Its ergonomic hand-sized design is convenient and practical.
- Order Soon - Only 1 Left In StockMore Due In February 19, 2016
$37.95
Part # 391-078
  • Modern, compact, ergonomic design
  • 40 to 130 dB SPL measurement range with 0.1 dB resolution
  • Frequency from 31.5 Hz to 8 KHz
  • 4 digit LCD with automatic backlit display
  • C-weighting
The Triplett SoniChek MC is a compact sound level meter with C weighting. Its ergonomic hand-sized design is convenient and practical. Features include a large auto backlit LCD display, MIN and MAX memories, auto power off, tripod mounting thread, and a non-slip rubber grip. The C weighting makes the SoniChek MC ideal for testing sound levels in home theaters, music performances, car audio, and other situations requiring broad frequency response.
  • BrandTriplett
  • ModelTSC-MC1
  • Part Number391-078
  • UPC614395001391
  • Product CategorySPL Meters / Audio Analyzers
    (2 Reviews)
  • Weight0.4 lbs.
View similar products to the Triplett TSC-MC1 SoniChek MC Mini Sound Lever Meter
in the SPL Meters / Audio Analyzers product category.
Triplett TSC-MC1 SoniChek MC Mini Sound Lever Meter is rated 4.5 out of 5 by 2.
Rated 4 out of 5 by from Does the job, but is limitedGood value for my application, basic gain adjustment and EQ'ing of my car and home speaker/amp systems. Just be aware that the product has limitations, such as: C-weighted only--not right for industrial noise measurement, etc., need A-weighted for that; and limited frequency measuring range of ~30Hz to ~8kHz, nice if it went higher but most low-priced dB meters have this limitation.
Date published: 2013-05-31
Rated 5 out of 5 by from perfect for quick checksI bought this unit for theater sound use.. so easy to walk around and check in the different seating areas. the max hold is very nice too. simple and effective!
Date published: 2012-02-06
  • 2016-02-13T06:38CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_391-078, PRD, sort_mostRecent
What type of meter should I use for car audio?
Asked by: Isaac l
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-12-21
Do SPL meters have an evenly weighted response across working range?
I read in the manual that this particular meter is +3 dB at 1 kHz but, it doesn't mention accuracy across the entire working range (31 Hz -8 kHz). These sort of meters seems like a cheap alternative to buying something like the OmniMic V2 only if the measurement is consistent and response sensitivity is characterized.
Asked by: kfrancis
This Meter is "C" weighted, which means it's response is adjusted to the way humans hear. C weighting is rolled off at the top and bottom end of the response and is intended mostly for peak SPL type measurements.This would not be a good alternative to a RTA or measurement system like Omnimic though due to the response variations.
Answered by: Chrisf
Date published: 2014-09-09
Frequency response at what tolerance.
The frequency response of the meter is 31.5 Hz. to 8 kHzplus or minus how many dBs ?at what pressure level ?Thank you.
Asked by: Sherlock
The resolution according to the descrption is .1db, which is pretty good. C-weighting refers to the 20-20KHz full audio spectrum, where as A-weighting measures human audio spectrum 20-12KHz. This is calibrated using the 1W/1M standard.
Answered by: Fanden
  • 2016-02-13T07:16CST
  • loc_en_US, sid_391-078, PRD, sort_recentQuestionsFirst
