Triplett 9650 Breaker Sniff-It Circuit Locator
Brand:|Model: 9650|Part # 391-142
Tired of having to turn on and off lights just to find one breaker? The 9650 is the solution; a simple digital breaker locator. Simply plug in the transmitter into any outlet or light socket then run the receiving unit in front of the breaker panel, when it lights up you have found the breaker.
OUT OF STOCK
Due In: 2/19/2016
$37.95
Part # 391-142
  • Micro processor controlled - reduces false readings
  • Fully automatic - no adjustments necessary
  • 120/220 VAC transmitter (250 VAC Max)
  • UL listed
  • Lifetime warranty
  • Audible & visual indication
  • Auto power off battery saver
Tired of having to turn on and off lights just to find one breaker? The 9650 is the solution; it is a simple digital breaker locator. Simply plug in the transmitter into any outlet or light socket (using adapter kit), then run the receiving unit in front of the breaker panel, when you hear the tone and see it light up you have found your breaker. The unit is fully automatic, so no adjustments are necessary, and it is controlled by a unique micro processor that reduces false readings. It uses one 9V battery (not included). The optional adapter kit includes a light socket adapter and an alligator clip adapter. UL listed. Lifetime warranty.
  • BrandTriplett
  • Model9650
  • Part Number391-142
  • UPC614395000790
  • Product CategoryAC Voltage Detectors / Circuit Testers
    (4 Reviews)
  • Weight0.3001 lbs.
View similar products to the Triplett 9650 Breaker Sniff-It Circuit Locator
in the AC Voltage Detectors / Circuit Testers product category.
Triplett 9650 Breaker Sniff-It Circuit Locator is rated 3.5 out of 5 by 4.
Rated 4 out of 5 by from Works wellEasy to use
Date published: 2010-03-08
Rated 3 out of 5 by from Triplett 9650 Breaker Sniff-It Circuit LocatorThis device saved us hours of tracking down some AV circuits that had never been documented. We found a projector connected to a lighting circuit, even though the electrician swore it was on a receptacle circuit in a panel in other wing.You do need to follow the directions carefully, especially about making one pass to "learn" the panel before going back to locate the traced circuit, and you also need to learn to hold the unit perpendicular and swing back and forth to narrow down the breaker. But used correctly, it quickly pays for itself. We made a believer out of the electrician who claimed it wouldn't work in long conduit runs or on 3 phase panels --it did!
Date published: 2009-11-25
Rated 4 out of 5 by from fairly reliableIt is a good prouduct overall. I live overseas and I mainly test 220 volt lines, and occasionally a custom 110 volt install. The only inaccuracy I found, was when testing 220 volt lines.Its much better than using a standard tone and probe.
Date published: 2008-02-12
Rated 3 out of 5 by from Wasn't the greatest in the world......but it worked for what I needed it to do and gave me relatively accurate readings. Maybe this other guy forgot to use the right end of the locator.
Date published: 2007-11-05
  • 2016-02-13T06:37CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_391-142, PRD, sort_mostRecent
