391-165_ALT_0
391-165_ALT_1
391-165_ALT_4
Triplett 3274 WireMaster Coax Cable Mapping Kit
Brand:|Model: 3274|Part # 391-165
The unique coax mapping kit is a simple, cost affective way to locate and identify installed wires. The kit comes with 8 BNC identifiers which reduce work time by being able to do batch mapping. Not only is it a mapping unit but it will also test for open lines and shorts/continuity issues.
The unique coax mapping kit is a simple, cost affective way to locate and identify installed wires. The kit comes with 8 BNC identifiers which reduce work time by being able to do batch mapping. Not only is it a mapping unit but it will also test for open lines and shorts/continuity issues. It was designed to be used with coax lines, however, with the appropriate adapter you can test just about any pair wire cable including, RCA, BNC, F, phone lines, and others. Kit includes: 8 remotes identifiers, padded carrying case, BNC male-to-male adapter, 9V battery. One year warranty.
Specifications: • AC and DC test: Detects voltages above 3 volts • Overload protection: Up to 120 volts AC/DC (no fuse required) • Display: Bright red and green LED's indicate the test results • Maximum cable length: Any length whose total DC resistance is less than 200 Ohms • Cables / Wires Tested: Any pair whose total DC resistance is less than 200 Ohms, and is unconnected to other equipment or circuitry • Continuity (SHORT): Continuity is indicated for resistances of 500 Ohms or less • OPEN test: OPEN is indicated for resistances of 10,000 Ohms or more • Battery: 9 Volt • Battery life: Approx 20 hours continuous use (alkaline battery).
  • BrandTriplett
  • Model3274
  • Part Number391-165
  • UPC614395001087
  • Product CategoryLAN / Coax Cable Testers & Mapping
  • Weight0.8801 lbs.
View similar products to the Triplett 3274 WireMaster Coax Cable Mapping Kit
in the LAN / Coax Cable Testers & Mapping product category.
