180-961_ALT_0
180-961_ALT_1
180-961_ALT_2
Toslink Optical To Digital Coaxial Converter
Brand:| Model: DAC-OC
The digital converter is the ideal problem solver when your equipment does not have the input or output you need. It will convert a digital signal (coaxial) to an optical signal (Toslink). 6 VDC power supply is included.
  • Converts optical signal to coaxial
  • Includes 6 VDC power supply
180-961
Weight: 0.56 lbs.
IN STOCK
List Price$36.99
You Save24%
$27.75
Buy 10-up$26.50
Part # 180-961
The digital converter is the ideal problem solver when your equipment does not have the input or output you need. It will convert an optical signal (Toslink) to a digital signal (coaxial). 6 VDC power supply is included.
  • BrandParts Express
  • ModelDAC-OC
  • Part Number180-961
  • UPC844632026034
  • Product CategoryDigital Audio/Video Converters
    (13 Reviews)
  • Weight0.56 lbs.
View similar products to the Toslink Optical To Digital Coaxial Converter
in the Digital Audio/Video Converters product category.
Toslink Optical To Digital Coaxial Converter is rated 4.5385 out of 5 by 13.
Rated 5 out of 5 by from Performed as promised right out of the box.The price was right and the performance great.
Date published: 2010-02-01
Rated 5 out of 5 by from Works as advertisedI ran an optical out from my mac mini and converted it to digital coax for my Sony receiver. Works great. 5.1 Channels!
Date published: 2009-03-14
Rated 4 out of 5 by from plug and playWorks as advertised. It solved my limited input problem. Seems a little bit expensive for what it is, though.
Date published: 2009-03-12
Rated 4 out of 5 by from I'm able to use newer gear on an old receiverThis little box saves me from having to add a optical switch to my Hometheater setup or manually move optical connectors as I can now use an optical digital output from my PC in one of the 2 coax inputs on my surround sound receiver. Product is as described - it worked immediately and the wall-wart is very small and light. There are no indicators or settings so it's a very simple setup.
Date published: 2008-10-19
Rated 4 out of 5 by from This product does exactly what it saysIt can't get any simpler. If your receiver doesn't have enough optical inputs this converter is a great solution......plug in your cables, insert power and that's it.
Date published: 2008-06-30
Rated 5 out of 5 by from outstandingthis little device helped me out alot and so far works just fine. I only have one optical connection (which is used already) on my reciever and 2 coxaial and wanted to add an x box 360 in surround sound, so this worked great never knew this was out there, if i have to, i will buy another one
Date published: 2008-01-21
Customer projects that include: Toslink Optical To Digital Coaxial Converter
