310-326_ALT_0
310-326_ALT_1
310-326_ALT_2
Topping TP60 T-Amp Tripath TA2022 50WPC (80WPC 4 Ohm) Mini Amplifier
Brand:|Model: TP60|Part # 310-326
The TP60 is Topping's flagship mini amplifier. It's designed using the venerable Tripath TA2022, dual toroidal transformers, and top-notch components throughout. When only the best will do, choose the Topping TP60.
List Price$399.99
You Save45%
$219.99
Part # 310-326
  • Amazing power output—up to 80W per channel
  • Valve-like soundstage with buttery midrange
  • Small footprint—11-3/8" L x 6-5/8" W x 2-3/8" H
  • Dual toroidal transformers with top quality components
  • Two sets of RCA stereo inputs with front-mounted source switch
  • 8 mm thick aluminum chassis
As the flagship of the Topping line of mini amplifiers, the TP60 is an exercise in no-holds barred design creating—quite possibly—the perfect amplifier for audiophiles. Flush with features, the Topping TP60 is built around the Tripath TA2022 which features DPP™ digital power processing and includes one dedicated toroidal transformer per channel for extremely stable rail voltages; making for an amplifier that lives up to its rated output without running out of gas.
Only the highest quality components were chosen to maintain signal fidelity from input to output, maintaining spaciousness and the critical midrange that most amplifiers don't seem to get right. Look inside and you'll find an Alps potentiometer, OMRON relays, ERO and CDE capacitors, Dale and Sanyo resistors, hand-wound inductors, gold-plated RCA input jacks and 5-way binding posts... no detail has been overlooked and loudspeaker protection is built-in to protect your investment.
One of the most amazing aspects of this amplifier is its size. Since this amplifier is up to 88% efficient, fans and extraordinarily large, space-consuming heatsinks are not required. What this means is that an amplifier that's only 11.375" long x 6.625" wide (faceplate is 7" wide and 3.375" H (including feet) can replace the huge amplifiers of yesteryear without sacrificing power.
Two sets of RCA inputs allows you to connect multiple sources that are switched via a front-mounted source select switch. Two sets of isolated 5-way binding posts offer banana, spade, speaker pin, and bare wire connectivity. A 5.5 foot IEC power cable with right-angle plug is included.
Specifications: • Power output: 2 x 80W (into 4Ω @ 10% THD), 2 x 48W (into 4Ω @ 0.1% THD), 2 x 50W (into 8Ω @ 10% THD), 2 x 27W (into 8Ω @ 0.1% THD) • Dynamic range: 102 dB • Signal-to-noise ratio: 98 dB • Power efficiency: 81% @ 80W into 4Ω, 88% @ 50W into 8Ω • Input sensitivity: 200 mV • Input voltage: 110 VAC, 60 Hz • Weight: 11 lbs. • Dimensions: 11.375" (288.9 mm) L x 6.625" (168.28 mm) W x 3.375" (85.73 mm) H.
Note: Class-T amplifiers will get interuption from RF transmissions or receptions, such as AM or FM radio.
  • Special FeaturesClass T
  • BrandTopping
  • ModelTP60
  • Part Number310-326
  • UPC844632093029
  • Product CategoryHome Audio Amplifiers
    (17 Reviews)
  • Weight12.05 lbs.
View similar products to the Topping TP60 T-Amp Tripath TA2022 50WPC (80WPC 4 Ohm) Mini Amplifier
in the Home Audio Amplifiers product category.
Topping TP60 T-Amp Tripath TA2022 50WPC (80WPC 4 Ohm) Mini Amplifier is rated 4.7647 out of 5 by 17.
Rated 5 out of 5 by from Solid, good sound.I am really pleased with this amplifier. Needed something better for the desktop at work to mate with my NHT Superzeros and Fiio X11 high resolution player (iPod killer) and I now have a really nice sounding setup. Have to keep the volume way down on this amp, but T-amps are at their best at low volumes. The big ol power supply in this thing make both its physical weight and the weight of the bass notes heavy. It really helps out the NHT's. I like having 2 channels as well so I can run my laptop into it when I want.Good build quality, good sound, and good looks. Bigger size than I realized I was buying, my other t amp was tiny in comparison, but there's a toroidal transformer in it like real audio gear!
Date published: 2015-01-30
Rated 5 out of 5 by from Excellent Value for the MoneyI bought this amp following my reading of earlier reviews and because I needed something more powerful than the Dayton DTA-100 micro-amp I currently own (driving a couple of smaller speakers connected to an Internet radio,....and very well). My initial impression of the TP-60 is that it produces a very clean sound and possesses more than enough power for my needs (currently driving tower speakers on the deck). The sound is crisp and precise, and the bass is smooth and powerful. I have not had the amp running for more than 12 total hrs., but I trust my appreciation for it will grow in the coming weeks as I introduce it to a greater variety of music and better speakers. I am pleased with this purchase and Parts Express has come through yet again.Although my ears may not be as discerning as those of an audiophile, I highly recommend this amplifier for its price and performance.
Date published: 2014-09-09
Rated 5 out of 5 by from "Giant Killer" is Right!I started my foray into small T-Amps with a Topping TP20MK2, but wanted something more powerful. The TP60 is just that -- and its sound/tone blows away the TP20! The TP60 is "warmer" with a better midrange and tighter upper-bass presence than the TP20, which seemed a little more tilted towards the highs and low-bass to me. (In that regard, the product description of "buttery mids" is right on target.) In short, the TP60 is a great sounding amp for the money. It's bigger than other T-Amps, thanks to the internal power supply, but still small enough to fit on a desk, and much smaller than larger integrated amps or receivers. Overall, I think its sound rivals much more expensive amps and receivers. (It reminds me a lot of some NAD and Marantz amps.)
Date published: 2014-08-05
Rated 5 out of 5 by from my 2nd topping ampI purchased this uniot mostly out of curosity. With the good reviews I did not think I was taking much of a chance. I was right this unit is great for what I need it for. Just for kicks I hooked it up to my Pioneer HPM-100s. Not the sound I get from my Phase Linear gear but very nice just the same.
Date published: 2014-07-06
Rated 5 out of 5 by from Amazing performanceI have been looking for an amplifier for my studio. It was meant to upgrade my Dayton TA-100 which seemed to have trouble driving my new set of tower speakers. Willing to spend up to 500, I read hundreds of reviews, and auditioned what I could within my price range. The last one I auditioned was the the NAD 326. It was hooked up to top of the line speakers, but it still sounded harsh.Seeing that the Topping TP60 had positive reviews, I ordered one. It is what other reviewers say: a little gem worth every penny.PROS:- Two toroidal transformers.- Great imaging- Warm sound- Tight, accurate bass- Rich sound- Able to drive with ease tower speakers (PSB Imagine T6)CONS:- Bright blue light- A faint hum audible only within 6 inches, but completely unnoticeable under most listening conditions.- A slight, hardly noticeable sibilance in some recordingsThere is no other amplifier what will give you this sound for this money.
Date published: 2014-05-21
Rated 4 out of 5 by from Great amp. It takes time to break in. Does not sound good out of the box.Like other reviewers state, this amp sounds harsh out of the box. As is breaks in it sounds better and better. I also own the Topping TP 20. I did not have this issue with the TP 20.As this amps breaks in, the sound gets more and more amazing. I am using it with Infinity bookshelf speakers but am shopping for higher end bookshelf speakers to take the sound to the next level. Use good cables.
Date published: 2013-09-03
  • 2016-02-07T06:31CST
  • co_hasreviews, tv_0, tr_17
  • loc_en_US, sid_310-326, PRD, sort_mostRecent
Can this Amp be used with an Stereo Equalizer to correct the sound to my liking? Because it doesn't have bass & treble controls on the unit like the excellently designed Lepai - LP-2020A+ T-Amp does.
Asked by: Pain for Fun 1980
Yes, but the EQ will have to be placed between the source and the amp itself.
Date published: 2015-10-01
Based on an answer to a question above, I assumed that the amplifier has a universal power supply and bought one. The box, however, has a label that reads "TP60-110V". Does it mean that this unit will not accept a 220V power source?
Asked by: kkayyar
The TP60 unit accepts only 110VAC 60 Hz standard 3 prong AC plug.
Answered by: TomI
Date published: 2015-02-09
Can an FM tuner be used by the unit since it is sensitive to rf transmissions including fm?
Asked by: cojimar
This amp uses dual torodial transformers and may radiate RF effecting FM in close range. If the unit is at least 2 feet away from the receiver the inductance should be held to a minimum.
Answered by: TomI
Date published: 2015-04-02
I just purchased the latest model of the TP 60. I live in Australia with 240v mains. The moment I turned the amp on with the 250v fuse the fuse blew. Is this a defective unit? Or is a different fuse required? Pls advise
Asked by: Sandym
Date published: 2014-11-04
Can this amplifier, or any similar amplifier, be used with a speaker system which includes a self-powered woofer?
Asked by: FRE0
As long as the subwoofer has speaker level inputs and outputs it will work with any of our small two channel amplifiers.
Date published: 2014-07-10
Can this run on 230/240 V AC or is it just US voltage?
Asked by: boris99
This will accept an input from 100-240 VAC.
  • 2016-02-07T07:10CST
  • co_hasquestionsanswers, tq_13
  • loc_en_US, sid_310-326, PRD, sort_recentQuestionsFirst
