Topping TP30-MK2 T-Amp Class T Amplifier with USB-DAC 15 WPC
Brand:|Model: TP30-MK2|Part # 310-313
The Topping TP30 Mk2 has a new auto on/off feature and a great new look while delivering the same great sound you are used to. The Mk2 is both an external USB sound-card and high quality mini amplifier based on the popular Tripath 2024C chip. This little amplifier is ideal for multimedia (USB-DAC) sound applications, desktop speakers, headphones, background music, ceiling, or wall speakers.
List Price$179.00
You Save39%
USB 2.0 Cable A to B Black 2m (6.6 ft.)
Qty: 1Part # 130-042
List Price:$6.99
*Domestic US orders only
Part # 310-313
  • Tripath-based for fantastic sound reproduction
  • USB-DAC input for multimedia sound applications
  • Small footprint ideal for desktop or where space is a consideration
  • Front panel 3.5mm headphone output
  • Front panel source selection (USB-RCA) and power on/off for easy access
  • Auto on/off function with PC
The Tripath TA2024C mini amplifier IC found in the Topping TP30 Mark II is an efficient, 2 x 15 watts @ 4 ohm (or 2 x 10 watts @ 8 ohm) power amplifier with separate pre amp for headphones.
The USB interface utilizes standard Windows audio class 1 drivers. The USB input allows you to play music directly from your computer via USB, requiring no additional software or drivers. The TP30-Mk2 is manufactured using only the highest quality components including Nichicon capacitors, KOA resistors, and ALPS volume control. A backlit volume control glows blue letting you know when amplifier is in operation.
If you're looking for a versatile, proven performance amplifier with a range of applications, the Topping TP30-Mk2 Tripath-based Class T digital amplifier with USB-DAC is the perfect choice for you!
Features: • USB or Stereo RCA input • 8 mm thick, CNC-machined aluminum front panel • Class-T Tripath TA2024 BTL configuration (for 4- to 8-ohm speaker) • 3.5 mm headphone output for headphone impedance 16 to 300 ohms • AC to DC power supply included – Input voltage: 100~240 VAC, 50/60 Hz (US Plug); Output: 12 VDC, 3A.
Specifications: • Output power: 15 watts x 2 @ 4 ohms, 10 watts x 2 @ 8 ohms • Sample bit/rate: 16-bit / 48 kHz • THD: 0.003% • THD+N @ 1 kHz: 0.012% • Weight: 1.17 lbs. • Dimensions: 4.8" W x 1.5" H x 7" D.
  • Special FeaturesClass T,USB Connectivity
  • BrandTopping
  • ModelTP30-MK2
  • Part Number310-313
  • UPC848864016894
  • Product CategoryHome Audio Amplifiers
    (3 Reviews)
  • Weight2.2000 lbs.
View similar products to the Topping TP30-MK2 T-Amp Class T Amplifier with USB-DAC 15 WPC
in the Home Audio Amplifiers product category.
