310-322_ALT_0
310-322_ALT_1
310-322_ALT_2
310-322_ALT_3
310-322_ALT_4
Topping TP22 T-Amp TK2050 (TC2000/TP2050) Class T Mini Amplifier 30WPC
Brand:|Model: TP22|Part # 310-322
If you are looking for a reference class amplifier to power your critical listening monitors, look no further. Topping's TP22 is an artfully executed amplifier that easily produces 30W per channel.
List Price$179.99
You Save47%
$95.99
Part # 310-322
  • Artfully executed audiophile-grade amplifier
  • Top-notch components used throughout the signal path
  • Designed using the Tripath TK2050 IC
  • 30W per channel into 4 ohm loads
  • Dual source input
Topping's TP22 Class T mini amplifier is perfectly suited powering nearfield monitors, bookshelf speakers... even modest tower speakers. Designed around the Tripath TK2050 IC, not only does this amplifier make power efficiently, it retains fidelity through each section of the signal chain.
Only the highest quality components are mounted onto the 24k gold-plated circuit board: An alps potentiometer, matched KOA resistors, Siemans, ERO, Nichicon, and Panasonic capacitors, Toko inductors, and OMRON low-loss relays make this amplifier better than state-of-the-art—it's truly a work of art, all covered in extruded aluminum chassis.
Loudspeaker protection is built-in, and this amplifier features dual, gold-plated stereo RCA inputs for connecting two sources. Gold-plated 5-way binding posts enable a multitude of loudspeaker connectivity. External power supply with 8.5 ft. of cord included. FCC, CE, and UL compliant.
Specifications: • Power output: 2 x 30W (4Ω @ 0.65% THD), 2 x 22W (4Ω @ 0.035% THD), 2 x 15W (8Ω @ 0.018% THD) • Input sensitivity: 200 mV • Input impedance 22 kΩ • Dimensions: 4.25" (108 mm) W x 7.09" (180 mm) L x 1.65" (42 mm) H.
  • Special FeaturesClass T
  • BrandTopping
  • ModelTP22
  • Part Number310-322
  • UPC844632093005
  • Product CategoryHome Audio Amplifiers
    (8 Reviews)
  • Weight2.75 lbs.
View similar products to the Topping TP22 T-Amp TK2050 (TC2000/TP2050) Class T Mini Amplifier 30WPC
in the Home Audio Amplifiers product category.
