310-310_ALT_0
310-310_ALT_1
310-310_ALT_2
310-310_ALT_3
310-310_ALT_4
Topping TP21 Class T Digital Mini Amplifier 25 WPC with Headphone Output
Brand:| Model: TP21
Product Video
The Topping TP21 features the Tripath 2021 Class T chip with 50 watts of power (25W per channel). Sleek design with advanced engineering for performance and longevity. For clean power in a mini amplifier that has headphone amplification, the Topping TP21 amplifier is the logical choice.
  • Tripath TA2021 Class-D/Class-T architecture for clean, efficient sound
  • High grade components provide audiophile performance
  • Ideal for multimedia sound applications
  • Space-saving small footprint perfect for desktop applications
  • Built in pre amp for use with headphones
  • Sleek faceplate making it unobtrusive
310-310
Weight: 2.4 lbs.
IN STOCK
List Price$149.99
Regular Price$109.50
You Save28%
Sale Price
$78.69
Part # 310-310
The Topping TP21 features brushed aluminum faceplate and black aluminum cabinet. The volume control is accentuated with a subtle blue LED illumination that when on surrounds the volume control. The unit features high quality gold RCA inputs and gold banana plug speaker connections. The on/off switch is located on the rear of the unit making the front of the amplifier clean and sleek.
A unique feature of the TP21 is the headphone output on the front faceplate. The headphone output has its own pre-amp that disables the speakers when headphones are plugged in and will easily drive any headphones in the 16-200 Ohm range. The Topping TP21 Class T amplifier is manufactured using the highest grade components, including ELNA audiophile grade capacitors, Dale resistors, and ALPS volume controls. Makes a great gift for yourself or any audio enthusiast.
Included in the box is the T Amp, a 12V 5A power supply, and USA 110V AC cord. If you've been searching for more power in a small amplifier that has headphone amplification, the Topping TP21 Tripath-based amplifier is the logical choice.
Features: Brushed aluminum faceplate and black aluminum case   Blue LED power indicator   T-Amp IC Tripath TA2021 Front-panel 3.5 mm headphone output Stereo (Left/Right) RCA audio inputs Left/right (+/-) pair speaker outputs Includes AC to DC power supply.
    Specifications: • Output power: 25W x 2 (4 ohms), 14W x 2 (8 ohms) Signal-to-noise ratio (SNR): 98 dB Dynamic range: 100 dB Input sensitivity: 200 mV THD: 00.03% @ 9W/4 ohms, 0.1% @ 12W/4 ohms, 0.1% @ 7W/8 ohms, 10% @ 25W/4 ohms, 10% @ 14W/8 ohms IHF-IM distortion: 0.1% @ 1W, 4 ohms Power requirements: DC 12V~14.6V, 5A, 5.5 mm x 2.1 mm jack Power efficiency: 81% @ 25W, 4 ohms; 88% @ 13.5W, 8 ohms Size: 4.45" W x 1.69" H x 6.77" D (113 x 43 x 172 mm) Weight: 1.37 lbs. (620 g).
      • Special FeaturesClass T
      • BrandTopping
      • ModelTP21
      • Part Number310-310
      • UPC844632090981
      • Product CategoryHome Audio Amplifiers
        (14 Reviews)
      • Weight2.4 lbs.
      View similar products to the Topping TP21 Class T Digital Mini Amplifier 25 WPC with Headphone Output
      in the Home Audio Amplifiers product category.
      Topping TP21 Class T Digital Mini Amplifier 25 WPC with Headphone Output is rated 4.5714 out of 5 by 14.
      Rated 5 out of 5 by from Great productSound quality of this little amp is excellent. It's extremely compact - so a good option for a computer desk, office, bedroom or kitchen.I'm using it in a bedroom with a couple of bookshelf speakers. I recently watched a movie, and I was impressed with the tight full bass considering I only had a set of bookshelf speakers. Sound was great with music as well.It's not going to shake your house; you'll need more than 25WPC for super high volume, but it goes as loud as I want to listen with no deterioration in quality at high volume. I think the ideal application for this product is a bedroom, kitchen, office, etc. where you want high quality audio, but you don't have the space or need for a 5.1/7.1 home theater.This also seems like a great audio component for a kid's room. This amp plus a set of used bookshelf speakers would make a great starter system for a kid to connect a laptop or MP3 player.I'm already considering putting another one of these in my kitchen and connecting it to a laptop and some mini speakers.Watch for sales. There are a few variants of these Topping amps, and sometimes one configuration or another seems to have a big discount.The one feature that I'd love to add to this is a remote for power and volume. However, given the price, it's understandable that it's just a manual volume knob and power switch.
      Date published: 2013-09-18
      Rated 5 out of 5 by from Topping TP21 ClassGreat amp . Quality parts and performance. Would recommend !
      Date published: 2013-07-08
      Rated 5 out of 5 by from TP21 Front Panel Power SwitchWho sez you cant have a front panel power switch!I really wanted one for convience so I went for it. Lots a room inside - pretty simple if yer brave enough!Nice amp - Using it to drive motorcycle helmet speakers. I gutted a pair of respectable studio headphones and stuck the elements inside my helmet. Didn't feel like I had quite enough headroom using the headphone jack so I wired the elements direct to the speaker outputs. As noted by many others - remember the negatives are not common to each other - takes 4 seperate wires. Sound is really nice. Unfortunately at 50+MPH wind noise is pretty bad but at low speeds the sound quality it really good. No fault of the gear - just the way it is!
      Date published: 2013-07-06
      Rated 5 out of 5 by from Clean Little AmpWe're using this to power a pair of JBL Control 1 5-1/4" speakers. It has a clean, crisp sound with good bass. This amp doesn't have enough power for much larger speakers, unless your driving horns. For a small installation of bookshelf speakers it sounds great, runs cold and comes in a nice aluminum box.
      Date published: 2013-06-18
      Rated 3 out of 5 by from Sweet sound but not as much kick as I expected.I purchased this and Lepai LP-2020A+ at same time. Topping is very clean sounding but just did not have as much kick with volume turned up as I expected. Was just driving some Minimus 7 and other smallish speakers when testing. Feature wise, it would be nice to have 3.5mm input jack. The Lepai was more than adequate for my needs at about a third the price.
      Date published: 2013-04-27
      Rated 5 out of 5 by from The Perfect portable AMP!!!I bought this amp to power a backpack with speakers. The sound is incredible. I take it everywhere with me, I use it for skiing, camping, and the beach. It is efficient enough to run off of 10AA rechargeable batteries for about 6 hours at a decent volume. The amp is well built and can take a beating. It has an incredible amount of Volume with sensitive speakers, 91db spl. Check out the youtube video of the pack.
      Date published: 2013-02-25
      Does a 200mv input bring this amplifier to maximum (25w/ch @ 4 ohms/ch) power?
      Asked by: E__M
      Hi, Good day! I'm planning to buy a Topping TP 21 for a portable boombox build. Before ordering I just want to be sure. Is it safe to run it with a 12v 7 ah sealed lead acid battery. I've seen a lot of Lepai running on 12v 7 ah source.  Thank you.
      Asked by: Jason29
      Yes this will work on any 12 VDC source.
      Date published: 2014-03-10
      This, or the TP41, or ...?
      I recently purchased a TP41 (from a different vendor; next time I'll be ordering from PE). It has an unreliable volume dial, so I am returning it. I'm wondering if it would be better to get the TP21, or the TP20Mk2, instead.My plans/needs: the amp is fed by a Logitech Squeezebox, which is fed FLAC files from my computer. The speakers are currently B&W 602s, but will be replaced (due to the B&Ws' size) by Overnight Sensations, once I finish them. The TP41 I got initially due to its power and the option of two inputs, but it's now twice the price of the TP21. Any avice appreciated, particularly on:a) the sound differences (if any) between the TP20, TP21, and TP41, andb) the power abilities. I will be playing the system in a fairly small room, at medium levels.I could also spring for one of the Toppings with a built in DAC, and skip the Squeezebox. Thanks!
      Asked by: bookmatch
      The only difference between this and a TP41 are the dual inputs and built in power supply. The amp sections are identical and will sound exactly the same. I would recommend the TP21 for two reasons, price and I have actually used it and it is a very good, reliable amplifier.
      Date published: 2013-07-19
      Powering via 12volt battery for off the grid use?
      Am new to Class T Amps and have some questions regarding the Topping TP21.I'm considering using this amp for a portable remote camp music system using my Sansa Fuze MP3 and a pair of bookshelf speakers. Would it work to power the amp from a Deep Cycle 12v Group 24 size Battery rated for 550 cold cranking amps? If so, where would I find a power cable to provide power to the amp's input connector?
      Asked by: NorCal
      The battery should power this unit fine. If your worried that the extra amps provided by the battery may harm the unit consider putting an inline fuse. If you don't mind destroying the included power supply you could splice the wire with butt connectors and some shrink wrap. I'm sure you could get a battery terminal cable from an auto parts store.
      Answered by: VictorE
      Date published: 2012-06-19
      Is this okay to use with a turntable and phono preamp?
      The word "digital" in the title has me wondering if an analog system would be a match with this amp.
      Asked by: knewburygreen
      Sure-go for it.
      Answered by: Fanden
      Date published: 2012-07-13
      What it the Headphone chipset ( it is not the same as the TA2021 tripath speaker driver )
      Asked by: BucketheadsTwin
      in such a small efficient package .. the headphone consists of some dropping resistors, non inductive for the headphone jack.. but till i get my hands on one ,or the various s,t,d, amps schematics i can only guess ...SOMEONE please enlighten me on these and a simple electronic crossover for these amps !!!
      Answered by: digitalhaven 53
      Date published: 2013-11-04
      Videos
      Customer projects that include: Topping TP21 Class T Digital Mini Amplifier 25 WPC with Headphone Output
