Topping TP20-MK2 T-Amp TA2020 Class T Mini Amplifier 25WPC
Brand:|Model: TP20-MK2|Part # 310-320
A Tripath TA2020 mini amplifier IC is the core of the Topping TP20-Mark 2's circuit design. It produces stunning, audiophile-quality performance in an ultra-compact chassis.
Part # 310-320
  • CNC-machined aluminum construction
  • Small size—fits almost anywhere
  • Up to 88% efficiency
  • Audiophile sound quality
  • Speaker protection circuitry
  • 14 VDC, 4A switching power supply included
  • Gold-plated 5-way binding post speaker outputs
The Topping TP20-Mark 2 mini amplifier is designed around the sought after Tripath TA2020 amplifier chip, making it extremely efficient while maintaining audiophile-grade, tube-like sound quality; additionally, the TP20-Mark 2 provides a wider soundstage and deeper bass.
This amplifier is ideal for driving small to large-sized loudspeakers, and its size makes it a perfect solution for desktop systems—the TP20-Mark 2 has enough output to rival many large stereo receivers. Machined aluminum construction adds a touch of class and the amp is manufactured using only the highest quality components, including Elna capacitors, Dale resistors, and ALPS volume controls.
Specifications: • Output power: 23 watts x 2 (4 ohms, 10% THD) • Tripath TA2020 T-Amp IC • Signal-to-noise ratio (SNR): 98 dB • Dynamic range: 98 dB • IHF-IM Distortion: 0.1% @ 1 watt (4 ohms) • THD Distortion: 0.03% @ 9 watts (4 ohms), 0.1% @ 10 watts (4 ohms), 0.1% @ 6 watts (8 ohms), 10% @ 23 watts (4 ohms), 10% @ 13 watts (8 ohms) • Power efficiency: 81% @ 20 watts (4 ohms), 88% @ 12 watts, (8 ohms) • Input sensitivity: 200 mV • RCA audio input jacks • Power indicator (Blue LED) • Dimensions: 3.54" W x 1.97" H x 6.38" D (90 x 50  x 162 mm).
  • Special FeaturesClass T
  • BrandTopping
  • ModelTP20-MK2
  • Part Number310-320
  • UPC844632092992
  • Product CategoryHome Audio Amplifiers
    (13 Reviews)
  • Weight2.1 lbs.
View similar products to the Topping TP20-MK2 T-Amp TA2020 Class T Mini Amplifier 25WPC
in the Home Audio Amplifiers product category.
