310-318_ALT_0
310-318_ALT_1
310-318_ALT_2
Topping TP10-MK4 TA2024 Class T Digital Mini Amplifier 15WPC
Brand:| Model: TP10-MK4
The Topping TP10-Mark 4 mini amplifier employs the renowned Tripath TA2024 chip to deliver amazing performance while residing in a stylish machined aluminum housing.
  • CNC-machined aluminum construction
  • Small sizeā€”fits almost anywhere
  • Up to 90% efficiency
  • Audiophile sound quality
  • Speaker protection circuitry
  • 12 VDC, 3A switching power supply included
  • Gold-plated 5-way binding post speaker outputs
310-318
Weight: 1.95 lbs.
IN STOCK
List Price$119.99
You Save25%
$89.00
Part # 310-318
Topping's TP10-Mark 4 mini amplifier is based on the venerable Tripath TA2024 amplifier chip, making it extremely efficient while offering world class tube-like sound quality. This amplifier is ideal for driving small to medium-sized bookshelf loudspeakers and single driver full-range loudspeakers, as well as being a perfect solution for desktop systems.
A machined aluminum enclosure adds a touch of class and contemporary style. The Topping TP10-Mark 4 is manufactured using only the highest quality components, including Elna capacitors, Dale resistors, and ALPS volume controls, resulting in near indestructible build quality.
Specifications: • Output power: 15W x 2 (4 ohms, 10% THD) • Tripath TA2024 T-Amp IC • Signal-to-noise ratio (SNR): 98 dB • Dynamic range: 98 dB • IHF-IM Distortion: 0.1% @ 1W (4 ohms) • THD Distortion: 0.03% @ 9W (4 ohms), 0.1% @ 10W (4 ohms), 10% @ 15W (4 ohms), 10% @ 10W (8 ohms) • Power efficiency: 81% @ 15W (4 ohms), 90% @ 10W, (8 ohms) • Input sensitivity: 200 mV • RCA audio input jacks • Power indicator (Blue LED) • Power input: 12 VDC-13.2 VDC, 5A • Dimensions: 3.54" (90 mm) W x 1.97" (50 mm) H x 6.38" (162 mm) D.
  • Power Output (RMS Per Channel @ 8 ohms)10 Watts
  • Special FeaturesClass T
  • BrandTopping
  • ModelTP10-MK4
  • Part Number310-318
  • UPC844632092985
  • Product CategoryHome Audio Amplifiers
    (2 Reviews)
  • Weight1.95 lbs.
View similar products to the Topping TP10-MK4 TA2024 Class T Digital Mini Amplifier 15WPC
in the Home Audio Amplifiers product category.
Topping TP10-MK4 TA2024 Class T Digital Mini Amplifier 15WPC is rated 4.5 out of 5 by 2.
Rated 5 out of 5 by from Excellent amp in the living room with 93 dB speakersThe sensitivity of the speakers defines how much power you need from the amp. The Topping TP10-MK4 performs great with my Klipsch Synergy F-1 speakers.This amp is a replacement for my Dayton Audio DTA-100a, which had serious problems with balance when the volume was low.This Topping is built very well and it sounds better than the Dayton.In order to qualify for free shipping I also ordered a 12 VDC 5A Switching Power Supply and replaced the 3A PSU that came with the Topping.
Date published: 2013-09-08
Rated 4 out of 5 by from Compact and rich sound: good amp for condo dwellersLike the DTA1, this amp is based on the 2024 chip. The sound is comparable, but (as advertised) the build quality is noticeably better on the Topping.In addition, the TP10 comes with a 3amp power supply with a cord that spans 9 feet; the DTA1 comes with only a 2amp wallwart with only 6 feet of cord.It sounds great. I wouldn't go so far as to say it sounds exactly like that tube radio I heard many years ago - and have never found an equal for - but it still provides the sound quality you would hope to find in a decent stereo.Regarding volume, the TP10 provides more than is alowed in a condo or apartment with shared walls: I paired it with the Dayton B652 speakers: #8 ohm.I would have preferred that Topping had placed the on/off switch on the front, as they did with the TP20, but since the amp is so small, it's a relatively minor issue. I suspect that the target audience for this amp are users who aren't going to turn it off very frequently.Why not go with the Topping TP20? Good question. I figured the TP10 provided more than enough power for my needs. If anybody has done a side by side comparison, I'd love to read your notes.
Date published: 2011-11-21
Is there much difference in sound between TP10 and TP20
Other than power output, is there much difference in sound between the Topping TP10 (2024 chip) and the TP20 (2020 chip)?The TP10 and TP20 are very similar in price, but I'm only leaning towards the TP10 due to the reduced power supply requirements.I'm planning on using this with the Dayton B652 speakers.
Asked by: Derek Data
Power output and a beefier power supply is the difference. FWIW, more than 3dB of extra punch is available with the TP20.
Answered by: WR22
Date published: 2012-03-25
Videos
Customer projects that include: Topping TP10-MK4 TA2024 Class T Digital Mini Amplifier 15WPC
