TOGGLER TB 3/8"-1/2" Drywall Anchors with Screws 20 Pcs.
Brand:|Model: TB|Part # 080-305
TOGGLER® hollow-wall anchors feature patented positive locking action that causes the anchor to become a weight-distributing truss inside the wall. TB anchors are designed for hollow walls made of 3/8"-1/2" material and are rated for 143 lb. loads in 1/2" drywall.
List Price$8.99
You Save28%
$6.50
Buy 4+$6.18
Part # 080-305
  • Designed to be used in 3/8"-1/2" thick hollow walls
  • Used to install the sprinkler system in the Tokyo subway system
  • Supports up to 143 lbs. when used in 1/2" drywall
  • Works with gypsum board, drywall, and plaster walls
TOGGLER® hollow-wall anchors feature a patented key-activated positive locking action that causes the anchor to become a rigid, weight-distributing truss in the wall. Light and medium loads are given maximum holding security with the smallest possible hole. This protects the wall from breakthrough. These rustproof anchors also feature the versatility to be used with wood screws or sheet metal screws and in gypsum board, drywall, or plaster walls.
The TB model of TOGGLER wall anchors is designed for hollow walls made of 3/8"-1/2" material. Ultimate tensile load is rated at 175 lbs. in 1/2" plywood, 97 lbs. in 3/8" drywall, 143 lbs. in 1/2" drywall, and 102 lbs. in 5/8" drywall (when used as a wedge anchor and not fully extended). Ultimate shear load is rated at 126 lbs. in 3/8" drywall, 167 lbs. in 1/2" drywall, and 214 lbs. in 5/8" drywall (when used as a wedge anchor and not fully extended). Industry safety standards recommend 1/4 of the ultimate load per anchor. Insertion hole required: 5/16". Screw range: #6 to #14. Package includes 20 TB anchors, 20 #8 x 1-1/2" screws, and two insertion keys.
  • BrandTOGGLER
  • ModelTB
  • Part Number080-305
  • UPC036296505257
  • Product CategoryWall Anchors
  • Weight0.9 lbs.
View similar products to the TOGGLER TB 3/8"-1/2" Drywall Anchors with Screws 20 Pcs.
in the Wall Anchors product category.
Videos
