TOGGLER BB 1/4"-20 Heavy-Duty Wall Anchors w/Bolts 2 Pcs.
Brand:|Model: BB|Part # 080-319
TOGGLER® SNAPTOGGLE® wall anchors hold up to twice the load of old-fashioned toggles and install in about 10 seconds. BA anchors are designed to work with 3/8" to 3-5/8" thick walls and 1/4"-20 bolts. Tensile strength has been rated at 265 lbs. in 1/2" drywall.
- Order Soon - Only 2 Left In StockMore Due In February 12, 2016
List Price$4.99
You Save35%
$3.25
Buy 4+$3.07
Part # 080-319
  • Mount flat panel HDTVs to walls without using the studs
  • Twice as strong as old-fashioned wing toggles
  • Installs in about 10 seconds
  • Reusable design
  • Supports up to 265 lbs. in 1/2" drywall
Having trouble finding the wall stud to mount your brand new HDTV? If you'd used the TOGGLER® SNAPTOGGLE® heavy-duty hollow-wall anchors you'd be done already. SNAPTOGGLE anchors hold up to twice the load of old-fashioned wing toggles (265 lbs. per anchor in 1/2" drywall without tying into a stud) and install in about 10 seconds, all while resisting shock and vibration. SNAPTOGGLE anchors pre-install without a bolt and can be installed with a screw gun. This allows one-person installations (instead of two), saving time and money. It's like having an extra pair of hands. Each anchor is reusable—remove the bolt without losing the anchor! A golden zinc plating has been applied to each SNAPTOGGLE anchor for maximum corrosion resistance. For use with materials such as cinder block, plaster, drywall, stucco, fiberglass, gypsum board, and concrete. Ideal for mounting flat panel HDTVs, heavy fans, speakers, garage doors, lighting fixtures, and machinery. BB TOGGLER SNAPTOGGLE anchors are designed to work in materials that are 3/8" to 3-5/8" thick and with 1/4"-20 threaded bolts. Ultimate tensile load has been rated at 265 lbs. in 1/2" drywall, 356 lbs. in 5/8" drywall, 1,080 lbs. in concrete block, and 1,283 lbs. when used in steel plates. Industry safety standards recommend 1/4 of the ultimate load per anchor. A 1/2" hole is required for installation. Package includes two BB anchors and two 1/4"-20 bolts.
  • BrandTOGGLER
  • ModelBB
  • Part Number080-319
  • UPC036296504007
  • Product CategoryWall Anchors
  • Weight0.1 lbs.
View similar products to the TOGGLER BB 1/4"-20 Heavy-Duty Wall Anchors w/Bolts 2 Pcs.
in the Wall Anchors product category.
Videos
