TOGGLER AF8 5/16" Flanged Solid-Wall Anchors 100 Pcs.
Brand:|Model: AF8|Part # 080-315
TOGGLER® ALLIGATOR® solid-wall anchors are the only anchors that extrude to the entire length of a screw. AF8 Toggler Alligator solid-wall anchors are designed to work with a 5/16" drill bit. The tensile strength has been rated at 3,083 lbs. in 4,000 psi concrete and 85 lbs. in 1/2" drywall.
List Price$20.99
You Save16%
$17.69
Buy 4+$16.80
Part # 080-315
  • Holds up to twice the weight of metal, adhesive, epoxy, or chemical anchors using the same screw
  • Extrudes up to the entire length of the screw and sets instantly
  • Resists shock and vibration
  • Opens to work in hollow walls or unexpected wall cavities
  • Non-toxic and rustproof
TOGGLER® ALLIGATOR® solid-wall anchors are the only anchors that extrude up to the entire length of a screw. The screw extrudes and compresses the anchor polymer into the wall of the hole. The anchor molds and conforms exactly to the surface of the hole—without chemicals. All forces supported by the screw are transmitted outwardly 360° to the wall surface of the hole. This provides greater holding power by distributing the force over the maximum area possible in concrete, brick, cinder block, wood, plaster, drywall, and stucco materials.
ALLIGATOR anchors are useful for mounting awnings, telephone equipment, hand rails, lighting fixtures, and digital satellite dishes. Anti-rotation fins prevent the screw from spinning for screw gun use. Hollow walls and unexpected cavities don't present a problem as the ALLIGATOR anchor is opened by the screw for secure anchoring, locking the screw thread into the teeth of the anchor to resist vibration and shock. AF8 solid-wall anchors are designed to work with a 5/16" drill bit. The ultimate tensile load has been rated at 3,083 lbs. in 4,000 psi concrete and 85 lbs. in 1/2" drywall. Ultimate shear strength is rated at 171 lbs. in 1/2" drywall. Industry safety standards recommend 1/4 of the ultimate load per anchor. AF8 anchors work with screw sizes #8 to 5/16". Package includes 100 AF8 anchors. Note: A 2" deep hole must be drilled into material for proper product use. Screws not included.
  • BrandTOGGLER
  • ModelAF8
  • Part Number080-315
  • UPC036296131029
  • Product CategoryWall Anchors
    (1 Reviews)
  • Weight0.28 lbs.
View similar products to the TOGGLER AF8 5/16" Flanged Solid-Wall Anchors 100 Pcs.
in the Wall Anchors product category.
TOGGLER AF8 5/16" Flanged Solid-Wall Anchors 100 Pcs. is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Great anchor for drywall & "blind" plaster work!I've been using these anchors for 3 years and have seldom been disappointed with the outcome. I'm a volunteer with the Rebuilding Together group and assist low income home owners, most of them living in old brick homes.Most frequently I'm anchoring grab bars around bath tubs. Finding a stud in the right place for a wood screw is pretty hit and miss. Quite frequently we need to mount through plastic, ceramic tile, plaster, and whatever's behind that, all in one install. When we use the right drill bit these anchors will get into and behind the layer and give a secure fix. I start with a smaller drill bit and ifI get lucky and hit wood, I just go with that and save the Alligator for the next hole. I'll also mention that these work quite well in wood holes that won't holda wood screw. That beats stuffing pieces of wood into the enlarged hole and hoping for the best.The Alligator appears to be made of nylon and is far superior to plastic anchors. And Parts Accessories ships fast and I don't have to bearthe expense of buying the screws with them. Good Job, Guys & Gals!!
Date published: 2014-12-30
  • 2016-02-14T07:19CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_080-315, PRD, sort_mostRecent
Videos
