TOGGLER AF6 1/4" Flanged Solid-Wall Anchors w/Screws 20 Pcs.
Brand:|Model: AF6|Part # 080-311
TOGGLER® ALLIGATOR® solid-wall anchors are the only anchors that extrude to the entire length of a screw. AF6 Toggler Alligator solid-wall anchors are designed to work with a 1/4" drill bit. The tensile strength has been rated at 2,633 lbs. in 4,000 psi concrete and 69 lbs. in 1/2" drywall.
List Price$8.99
You Save28%
$6.50
Buy 4+$6.18
Part # 080-311
  • Holds up to twice the weight of metal, adhesive, epoxy, or chemical anchors using the same screw
  • Extrudes up to the entire length of the screw and sets instantly
  • Resists shock and vibration
  • Opens to work in hollow walls or unexpected wall cavities
  • Non-toxic and rustproof
TOGGLER® ALLIGATOR® solid-wall anchors are the only anchors that extrude up to the entire length of a screw. The screw extrudes and compresses the anchor polymer into the wall of the hole. The anchor molds and conforms exactly to the surface of the hole—without chemicals. All forces supported by the screw are transmitted outwardly 360° to the wall surface of the hole. This provides greater holding power by distributing the force over the maximum area possible in concrete, brick, cinder block, wood, plaster, drywall, and stucco materials.
ALLIGATOR anchors are useful for mounting awnings, telephone equipment, hand rails, lighting fixtures, and digital satellite dishes. Anti-rotation fins prevent the screw from spinning for screw gun use. Hollow walls and unexpected cavities don't present a problem as the ALLIGATOR anchor is opened by the screw for secure anchoring, locking the screw thread into the teeth of the anchor to resist vibration and shock. AF6 solid-wall anchors are designed to work with a 1/4" drill bit. The ultimate tensile load has been rated at 2,633 lbs. in 4,000 psi concrete and 69 lbs. in 1/2" drywall. Ultimate shear load is rated at 153 lbs. in 1/2" drywall. Industry safety standards recommend 1/4 of the ultimate load per anchor. AF6 anchors work with screw sizes #6 to #14. Package includes 20 AF6 anchors and 20 #10 x 1-1/2" screws. Note: A 1-3/4" deep hole must be drilled into material for proper product use.
  • BrandTOGGLER
  • ModelAF6
  • Part Number080-311
  • UPC036296504755
  • Product CategoryWall Anchors
  • Weight0.5 lbs.
View similar products to the TOGGLER AF6 1/4" Flanged Solid-Wall Anchors w/Screws 20 Pcs.
in the Wall Anchors product category.
Videos
