TOA HB-1 In-Wall/Ceiling Mount 8" Subwoofer 240W
Brand:|Model: HB-1|Part # 246-638
TOA's HB-1 In-Wall/In-Ceiling Subwoofer is the ideal solution for adding low frequency enhancement to commercial, residential, and retail sound systems.
  • Minimum-depth design for recessed flush-mounting in only 4.1" of available depth
  • Wall-mounts between 16" spaced wall studs
  • Ceiling-mounts using supplied rigging points
  • Tuned, ported enclosure for deep bass and low distortion
  • Acoustic bandpass filter design eliminates need for external crossover
  • Heavy-duty 8" woofer with ferrite magnet
  • Solid, vibration-free steel enclosure acts as heat-sink to dissipate excessive heat
TOA's HB-1 In-Wall/In-Ceiling Subwoofer is the ideal solution for adding low frequency enhancement to commercial, residential, and retail sound systems. The HB-1's unique minimum-depth design allows discreet flush-mount installation in ceiling structures or in walls between studs spaced on 16" centers. The HB-1 features a tuned, ported enclosure and a heavy-duty 8" woofer for high power handling and extended low frequency response. An acoustic bandpass filter design eliminates the need for an external crossover. The solidly constructed steel enclosure also acts as a heat-sink to dissipate excessive heat from the speaker component. Other features include a paintable grill and removable terminal block.
Specifications: • Power handling: 240W continuous program • Frequency response: 45 to 200 Hz (-10 dB, 1/2 space) • Sensitivity: 91 dB SPL (1 W / 1 m, 1/2 space) • Dimensions: 21.42" H x 16.93" W x 5.32" D.
  • Input Rating8 ohm
  • Mounting StyleIn-ceiling
  • Special FeaturesEnclosed Back
  • Woofer Diameter8"
  • BrandTOA Electronics
  • ModelHB-1
  • Part Number246-638
  • UPC844632065767
  • Product CategoryIn-Ceiling / On-Ceiling Speakers
  • Weight30.2 lbs.
View similar products to the TOA HB-1 In-Wall/Ceiling Mount 8" Subwoofer 240W
in the In-Ceiling / On-Ceiling Speakers product category.
