302-136_ALT_0
TIC TFS5SL 6-1/2" 2-Way Rock Speaker Slate Pair
Brand:|Model: TFS5SL|Part # 302-136
There's a reason TIC are the undisputed leaders in landscape speakers - no one else has mastered their blend of fidelity, longevity, and aesthetics!
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$159.95
You Save24%
$120.90
Part # 302-136
  • Outdoor sound that disappears into the landscape
  • Weather resistant 6-1/2" poly woofer and 2" aluminum tweeter
  • True 180° sound
  • Sealed cabinet made of aerospace-grade composite material
TIC's Terra-Form® TFS5s are designed to fill your outdoor setting with 180° of sound while disappearing into the landscape. Sealed cabinets made of an aerospace-grade composite material offer years of use. A polypropylene 6-1/2" woofer with butyl rubber surround and an anodized basket has been selected for its ability to repel water and moisture while delivering great sound. Coaxially mounted to the woofer is a corrosion-resistant 1" all-aluminum tweeter that produces clear highs. Use the TIC SP70VTA external constant voltage transformer to turn this speaker into a multi-use distributed 25v 70v 100v outdoor speaker system. Surge protection is built into each speaker as is a surface mount waterproof cable connector.
Specifications: • Drivers: 6-1/2" poly woofer, 2" aluminum cone tweeter • Power handling: 55 watts RMS/150 watts max • Impedance: 8 ohms (optional external SP70VTA switchable 70V transformer available) • Frequency response: 74-20,000 Hz • Sensitivity: 88 dB 1W/1m • Dimensions: 14.5" x 11" x 13.75" • Sold in pairs.
  • Input Rating8 ohm
  • Special FeaturesWeatherproof
  • Woofer Diameter6-1/2"
  • Configuration2-way
  • ColorSlate
  • BrandTIC
  • ModelTFS5SL
  • Part Number302-136
  • UPC735120211158
  • Product CategoryGarden & Landscape Outdoor Speakers
  • Unit of MeasurePR
    (2 Reviews)
  • Weight16 lbs.
View similar products to the TIC TFS5SL 6-1/2" 2-Way Rock Speaker Slate Pair
in the Garden & Landscape Outdoor Speakers product category.
TIC TFS5SL 6-1/2" 2-Way Rock Speaker Slate Pair is rated 4.0 out of 5 by 2.
Rated 3 out of 5 by from Best for larger spacesI didn't expect audiophile-quality speakers or anything, but even so I was a little bit let down. Had to fiddle quite a bit with the EQ as they seem to be a bit muddy in the bass, dry in the midrange and rolled off in the high top end.The "180 degree sound" makes them very in-your-face when you are close so I would recommend installing them a good distance (10ft+) from the listening area. I have mine on a smaller patio and find that I need to keep the volume quite low to avoid interfering with conversation.The build quality seem solid enough. The compression fit connector works well and does look like it will keep moisture out. They blend into my landscape attractively and are as convincing as other higher-priced fake-looking rocks.I give them adequate marks for the value relative to the price. If installed correctly, they'll provide good performance for background music outdoors.
Date published: 2011-06-13
Rated 5 out of 5 by from Worth the price and then someI was very hessistant on purchasing this product and the GS50 Subwoofer. I had to run 100' of underground speaker wire to get these out to my pool and between the distance and the large sound area my expectaions were very low. Suprisingly this setup sounds wonderful. I highly reccomend these products.
Date published: 2008-08-11
  • 2016-02-07T06:34CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_302-136, PRD, sort_mostRecent
Videos
