TIC TFS0SL 4-1/2" 2-Way Rock Speaker Slate Pair
Brand:|Model: TFS0SL|Part # 302-132
Landscape speakers should sound great and blend unobtrusively into their environment. The TIC TFS0 succeed on both counts!
Comparable Items In Stock:
Part # 302-132
  • Add outdoor sound without adding an eyesore
  • Water resistant poly woofer and aluminum tweeter
  • Sealed cabinet made of aerospace-grade composite material
Add audio to a yard or business landscape unobtrusively with TIC's Terra-Forms® TFS0 4.5" 2-way rock speakers. Sealed aerospace-grade multi-layer composite cabinetry keeps water out for years of enjoyment. A 4.5" woofer uses an injection-molded polypropylene cone for great sound, output, and resiliency. You won't see this woofer break-down after a downpour. An all-aluminum 1" cone tweeter is coaxially mounted on the woofer and resists corrosion, humidity, and anything else Mother Nature throws at it. A 4.5 kHz crossover is employed for a smooth transition from highs to lows without any noticeable dropout. Use the TIC SP70T external constant voltage transformer to turn this speaker into a multi-use distributed 25v, 70v, or 100v outdoor speaker system. Speaker surge protection is built-in.
Specifications: • Drivers: 4.5" poly woofer, 1" aluminum cone tweeter • Power handling: 40 watts RMS/75 watts max • Impedance: 8 ohms (optional external SP70VTA switchable 70V transformer available) • Frequency response: 77-19,000 Hz • Sensitivity: 84 dB 1W/1m • Dimensions: 8" x 10" x 9" • Sold in pairs.
  • Input Rating8 ohm
  • Special FeaturesWeatherproof
  • Woofer Diameter4-1/2"
  • Configuration2-way
  • ColorSlate
  • BrandTIC
  • ModelTFS0SL
  • Part Number302-132
  • UPC735120201081
  • Product CategoryGarden & Landscape Outdoor Speakers
  • Unit of MeasurePR
    (1 Reviews)
  • Weight13 lbs.
View similar products to the TIC TFS0SL 4-1/2" 2-Way Rock Speaker Slate Pair
in the Garden & Landscape Outdoor Speakers product category.
