302-112_ALT_0
302-112_ALT_1
TIC SP70VTA 25V 70V 100V External Transformer
Brand:| Model: SP70VTA
TIC's SP70VTA transformer turns any 8 ohm speaker into a 70V speaker suitable for commercial installation.
  • Tap settings of 2.5W, 5W, 10W, 15W, and 20W
  • Impact resistant, weatherproof design
  • Universal design, but made especially for TIC outdoor speakers
302-112
Weight: 0.9 lbs.
IN STOCK
List Price$34.95
You Save14%
$29.97
Part # 302-112
TIC's SP70VTA transformer turns any 8 ohm speaker into a commercial-style constant voltage speaker. The impact resistant, weatherproof ABS design is especially useful when installing TIC outdoor speakers in a commercial setting. Cable seals prevent shorts caused by moisture, and corrosion is kept to a minimum. Tool less tap selections of 2.5, 5, 10, 15, and 20 watts are available when used with an 8 ohm speaker on 25V, 70V, and 100V systems.
  • BrandTIC
  • ModelSP70VTA
  • Part Number302-112
  • UPC735120120009
  • Product CategoryLine-Matching Transformers
  • Weight0.9 lbs.
View similar products to the TIC SP70VTA 25V 70V 100V External Transformer
in the Line-Matching Transformers product category.
I'm planning on connecting 4 tic gs3 outdoor speakers in my yard including 1 tic gs50 subwoofer. Are these external transformers a necessity for connecting each speaker to the receiver? I'm using a kenwood vr-6070 and its power output is 100 watts per ch.
Asked by: Jpetite
These transformers are not necessary for use with a standard amplifier. They are only required for a commercial type 70 volt system.
Date published: 2014-07-17
how to set this xformer
I have 12 outdoor 8 ohm rock speakers, they are quite a distance from the amp. I chose a Crown CTS600 amp. I wired everything from the amp to the these xformers as if they were in a 70V arrangement, meaning i didn't worry about trying to match impedance. these xformers came set to 8 ohm, so i left them as such. i connected everything to the amp and turned it on and they appear to work fine. but is this okay? why are there selections for 8 ohm, 5W, 10W, etc? will this work as i've got it set up?
Asked by: Wlanmaster
should work ok. The higher wattage settings are for "matching" total power to the speaker[s].But if you got it working, dont fix it. Check your amp for overheating...it will shut down if overloaded.
Answered by: Fanden
Date published: 2012-03-30
Customer projects that include: TIC SP70VTA 25V 70V 100V External Transformer
