TIC GS50 Omni-Directional Outdoor Subwoofer
Brand:|Model: GS50|Part # 302-129
The GS50 provides great bass reinforcement for TIC GS3, GS5, or any other outdoor speakers.
List Price$169.95
You Save25%
$126.87
Part # 302-129
  • True omni-directional 360° sound
  • The perfect subwoofer to compliment your outdoor speaker system
  • Sealed aerospace grade cabinetry provides reliable protection from the elements
  • 250W max power handling
This outdoor subwoofer is the great compliment to your outdoor speaker system. A high impact ABS housing blends into almost any surroundings, making this a perfect speaker to hide in the garden. Use the TIC SP70VTA external constant voltage transformer to turn this speaker into a multi-use distributed 25v, 70v, or 100v outdoor speaker system. A watertight aerospace-grade cabinet provides reliable protection from the elements.  The GS50 includes a one meter 4-conductor pigtail for input (two for left, two for right) and a one-meter 4-conductor pigtail for high-passed output to satellite speakers.
Specifications: • Woofer size: 8" • Frequency range: 25-110 Hz • SPL: 86 dB 1W/1m • Impedance: 8 ohms • Power handling: 125 watts RMS/250 watts max • Voice coil diameter: 1-1/2" • Mfg. #GS50 • Dimensions: 12.5" x 12.5" x 13".
  • Input Rating8 ohm
  • Special FeaturesWeatherproof
  • Woofer Diameter8"
  • Configuration2-way
  • ColorGreen
  • BrandTIC
  • ModelGS50
  • Part Number302-129
  • UPC735120100506
  • Product CategoryGarden & Landscape Outdoor Speakers
    (9 Reviews)
  • Weight15 lbs.
View similar products to the TIC GS50 Omni-Directional Outdoor Subwoofer
in the Garden & Landscape Outdoor Speakers product category.
TIC GS50 Omni-Directional Outdoor Subwoofer is rated 3.4444 out of 5 by 9.
Rated 4 out of 5 by from Bury it!Like any sub, placement is everything. Before deciding on its final position, hook it up and have some one move it from location to location while you sit in the listening area. The enclosure is plastic and flimsy but here's the fix, bury it! Yes the manufacturer even recommends a depth! This stiffens the enclosure enough to allow the driver to do its job without the thin plastic robbing all the energy from the driver. It can even be buried in a large planter and surrounded with flowers or plants.. Now that's stealth! Way cool... Adds a good amount of punch to a small 2 channel speaker set-up.
Date published: 2014-06-16
Rated 3 out of 5 by from TIC GS50 Not BadI initially thought this subwoofer would fill in the added basemy outdoor system lacked. It does to a degree if you stand in the proper place. This is the biggest model sub that Tic offers and for that reason I would give it a not bad. The quality of the product is good it just doesn't add enough base over a big enough area.
Date published: 2012-05-25
Rated 4 out of 5 by from GOOD PRODUCTNO ISSUES. IT WORKED AS REPORTED. I USED BOSE 151 WITH THE SUBWOOFER. SOUNDS GREAT.
Date published: 2009-07-12
Rated 4 out of 5 by from Perfect Bass for the Buck!Added this sub to existing tic system & WOW! This sub put out just the right ammount of low end freq. filling out my system perfectly! Highly reccomend this sub with the tic mini omni pair. Great sound for the price. Also, recomend picking-up extra underground cable for placement...sub has only a few feet of cable that can limit installation location. Location is key in optimum speaker system performance.
Date published: 2009-06-26
Rated 4 out of 5 by from It fills the Hz mid Low to Mid Hz for you!!!The GS50 fills the gap's in Hz for your outdoor application. in Mid Low and Mid Hz range a must have!!!
Date published: 2009-05-16
Rated 2 out of 5 by from Ok for a small boostThis product is OK for a small boost of outdoor speakers- taking some of the heavy weight off the rest of your system. It does not compare to the impact a powered subwoofer has but does help
Date published: 2008-09-12
  • 2016-02-06T06:35CST
  • co_hasreviews, tv_0, tr_9
  • loc_en_US, sid_302-129, PRD, sort_mostRecent
If used in a 2.1 set-up (sub-out from main amp >> 2-channel-sub amp), would this subwoofer simply hook up to the L and R channels of the sub-amp? Alternately, would it sound better to wire per MFG instructions (no sub-amp)?
Asked by: hlwimmer
This is a dual channel subwoofer so it has left and right connections.
Date published: 2015-05-28
I understand that this sub is intended to be paired with stereo satellite speakers, necessitating 4 input leads. I intend to use it as a standalone subwoofer. Is the driver dual voice coil (4 ohm + 4 ohm)? Suggested wiring configuration for 1 and 2 subs?
Asked by: Mike Deez
This subwoofer has dual 8 ohm coils. If you want to run multiple subs you will have to either use separate amplification for the subwoofers themselves, or use multiple channels from more than one amplifier.
Date published: 2015-04-17
Is this a subwoofer or full range speaker?
It appears to be a subwoofer but details say it has a 2" tweeter with frequency response to 110,000 Hz.
Asked by: Charlie G
I apologize for the mistake(s) in our description, it has been addressed. This is a subwoofer, and only a subwoofer. There is no tweeter present in the enclosure, and the frequency response is up to about 110Hz, not 110kHz. Thank you for pointing out our oversight.
Answered by: RussR
How would this be hooked up in a typical system?
Right now, I have two speakers hooked up outside. Would this need a special "sub-woofer out" line, or would I have to piggy back off one of my current pair?
Asked by: tfrei
This product does not feature a pass-thru low pass circuit or amplifier, so it would require an amplifier and low frequency pre-amplified output signal. I'd suggest using the LFE or sub-out on your receiver, and one of the amplifiers linked below. If you don't have a pre-out on your receiver, the plate amps referenced below will accommodate using a speaker-level source, with the pass-thru arrangement as you described. The APA150 will accept a line-level (pre-out, sub or LFE) input signal only.
Answered by: RussR
Date published: 2015-04-30
  • 2016-02-06T08:05CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_302-129, PRD, sort_recentQuestionsFirst
