TIC AMP10 Exterior Amplifier/Receiver
Brand:|Model: AMP10|Part # 302-150
TIC's weatherproof AMP10 is designed to be used exclusively outdoors—at the beach, for block parties, or by the pool. This four channel amplifier/receiver features CD, MP3, and iPod connectivity. Also included is an AM/FM tuner and microphone inputs for backyard karaoke.
List Price$149.95
You Save25%
$111.94
Buy 4+$107.14
Part # 302-150
  • Weatherproof design with backlit LCD display
  • 4 x 5W peak power output per speaker
  • CD, MP3 player, and microphone audio inputs
  • AM/FM tuner built-in
  • 12 VDC power supply and cigarette lighter adapter included
TIC's weatherproof AMP10 is designed to be used exclusively outdoors at the beach, for block parties, by the pool, or for tailgating at games. Complicated installations are avoided by moving the small amplifier and signal sources outside near the speakers. Four channels of amplification deliver up to 5 watts of peak power per speaker. The AMP10 accepts 4 to 8 ohm speakers, opening up speaker selection possibilities. RCA inputs for a CD player and MP3 player, as well as a 3.5 mm input for iPods, are provided. A full featured AM/FM tuner with preset function is built-in so that you don't miss a second of the ballgame or race while doing yard work. Two 3.5 mm dynamic microphone inputs will make your backyard the place to be for karaoke (dynamic microphones not included). System expandability is supported with a 3.5 mm stereo output for daisy chaining amplifiers.
Included with the AMP10 is a 12 VDC switching power supply that runs off of 100 to 240 VAC, a cigarette lighter power adapter, two 6 ft. RCA to wire speaker cables, a 3 ft. stereo 3.5 mm male to male patch cable, a 6 ft. stereo 3.5 mm to stereo RCA adapter cable, a mono male 3.5 mm to 1/4" female adapter, and AM and FM antennas. Dimensions: 2-1/4" H x 7-7/8" W x 4-3/4" D.
  • Power Output Per Channel2.5 Watts
  • Receiver Type2 Channel Stereo
  • BrandTIC
  • ModelAMP10
  • Part Number302-150
  • UPC735120500009
  • Product CategoryHome Theater Receivers & Stereo Receivers
    (17 Reviews)
  • Weight3 lbs.
View similar products to the TIC AMP10 Exterior Amplifier/Receiver
in the Home Theater Receivers & Stereo Receivers product category.
TIC AMP10 Exterior Amplifier/Receiver is rated 3.1176 out of 5 by 17.
Rated 4 out of 5 by from Durable- 3 years and going strong, rain+snow incl.I've had this thing outside on a table near my fire pit for three years- I never bring it inside, and it is always hooked up. It has survived 3 Pennsylvania snowy winters and humid summers and performs like the day I got it- that said, it doesnt quite have the power i would like, but for the money i can just buy a second one to power two additional speakers. I am using it in combination with the green outside speakers sold here on PE( name escapes me) and they get loud enough that my neighbors occasionally stop by to ask me to turn them down. even though they are several hundred feet away. Reception depends on the antenna you choose, out of the box its a bit rough in this regard, but works great when plugged into a phone or ipod with rca to 3.5mm jack cable.
Date published: 2015-05-11
Rated 4 out of 5 by from It worksI hooked it up and had music on the deck for the 4th of July.It did as advertised, The video helped me decide to buy,
Date published: 2014-07-09
Rated 3 out of 5 by from Inexpensice Outside StereoThis unit is good... not great and not bad, just good. What you should expenct for the cost of this product. FM reception is mediocre at best. Works well with an AUX system (MP3 or iPhone) to supply music because FM is just weak. If you are looking for a "MacDaddy" unit go elsewhere but if you are looking for something for outside to produce OK reliable sound from an iPod/pad/phone... it is a good buy.
Date published: 2013-08-05
Rated 3 out of 5 by from You get what you pay for.The TIC AMP10 Exterior Amplifier/Receiver is pretty much what you would expect for the price. Although it's kind of a "one-of-a-kind" product in that it's a portable receiver with a little power to drive some speakers, it falls a little short on performance. It claims 25w "continuous"....I doubt that very much. It's somewhat cheaply made, but it's also cheap in price, so that makes sense. First one shipped wasn't working on delivery, sounded like something got loose inside on shipping, but PE was awesome in exchanging it quickly #Thanks guys!#. It's easy enough to use but the reception is average at best. Don't expect Hi-Fi sound, so you won't be disappointed. I'd categorize this item as somewhat of a gimmick. If you want something for a quick solution, this works...if you want something that sounds good, look elsewhere.
Date published: 2013-08-02
Rated 2 out of 5 by from Good features...short lifeProduct lasted 3 months then died. Output was very limited and could barely hear the speakers over the outside background noise
Date published: 2013-01-17
Rated 1 out of 5 by from Didn't work out of the boxTook the unit out and hooked it up, but didn't work. Only 2 of the 4 speaker connections worked, the FM radio would not change stations, and there was so much noise on the output when hooked to the I-Pod the songs werent even reconiazble. Don't bother.
Date published: 2012-07-30
  • 2016-02-12T06:14CST
  • co_hasreviews, tv_0, tr_17
  • loc_en_US, sid_302-150, PRD, sort_mostRecent
My TIC AMP10 has stopped working.  This is the second on I have purchased in 2 years. I think it might be the power supply. Are there replacement parts for this item sold anywhere?
Asked by: jfbarriv
Date published: 2015-08-12
CAn it accept external speakers?
Asked by: Joey1168
Yes this amplifier has four speaker outputs for external speakers.
Date published: 2015-04-21
I am purchasing a TCI AMP 10 for outdoor use and want to mount it to the fascia board or the wall behind my TV.  What bracket does your company sell to mount it?
Asked by: Mark Wammack
We do not have any brackets available for mounting this amplifier specifically. You will have to use a small shelf or something custom fabricated.
Is there any way to control this unit via IR?  Also, are both pairs of speakers live simultaneously, or can they be turned off in an A/B/AB style configuration?
Asked by: Russ_K
There is no IR eye on this unit. You could control it with a Bluetooth adapter. The A/B speakers are always active.
Answered by: TomI
Date published: 2015-03-10
Will this unit rust if I leave it outside hooked up to my speakers?  If so, what can I buy or do so that they will last longer? (without bringing it in and outside)
Asked by: Dante13
This unit is designed to be left outside and is made from plastic and weather resistant. This is the only outdoor amplifier we have to offer.
Date published: 2014-09-24
will this amp power a pair of Bose Free Space 51 Speakers
Asked by: zackfighter
Yes this will power those without a problem.
Date published: 2014-09-23
  • 2016-02-12T06:49CST
  • co_hasquestionsanswers, tq_7
  • loc_en_US, sid_302-150, PRD, sort_recentQuestionsFirst
Videos
