250-010_ALT_0
250-010_ALT_1
Thermocool 110 VAC Muffin Cooling Fan 80 x 25mm Sleeve Bearing 19 CFM
Brand:|Model: G8025HAS|Part # 250-010
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product.
List Price$19.99
You Save55%
$9.00
Buy 10+$8.19
Part # 250-010
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product. Thermocool fans are ideal for use in computer systems, portable CD and DVD players, stereo components, overhead projectors, laptop computers, and many other electronic applications where circulation is a key concern.
Specifications: • Power: 120V AC, 60 Hz • Sleeve bearing • Lead wire connection • 0.13 amps • 2300 RPM • 27dB noise level • 19 CFM air flow • Dimensions: 80 mm (H) x 80 mm (W) x 25 mm (D).
  • Operating Voltage110~120 VAC
  • Size80 mm
  • Bearing TypeSleeve Bearing
  • BrandThermocool
  • ModelG8025HAS
  • Part Number250-010
  • UPC656403880253
  • Product CategoryEquipment Cooling
    (4 Reviews)
  • Weight0.6 lbs.
View similar products to the Thermocool 110 VAC Muffin Cooling Fan 80 x 25mm Sleeve Bearing 19 CFM
in the Equipment Cooling product category.
Thermocool 110 VAC Muffin Cooling Fan 80 x 25mm Sleeve Bearing 19 CFM is rated 4.5 out of 5 by 4.
Rated 3 out of 5 by from Seems well build, but noisy.It seems like a nice sturdy unit and it does move a lot of air. But I had it mounted in a guitar combo amp and it caused a bad 60 cycle hum. I don't think that was the fan's fault though. The one issue I did have with this was how loud it was. It was exceptionally louder than what I expected. Perhaps that could have been fixed by reducing the speed?
Date published: 2013-06-22
Rated 5 out of 5 by from Great workI set this fan to my ONKYO receiver for cool down heat inside. Was ONKYO receiver got HDMI failer problems.Ifix bymyself and decide install the new fan for drainout the heat from the receiver cabinet. Now its working good and any more lost video even running full 24 hours. Quiet and enought amount air supplied. Also fast shipping and packing is tight nwell.
Date published: 2012-12-16
Rated 5 out of 5 by from Appears well-builtI purchased this fan to replace the failed built-in DC fan of my stereo receiver. I intended to screw it onto the back of the receiver over the old fan hole. I chose an AC fan so that I would not have to obtain an external DC supply and could simply run the AC fan off the switched outlet of the receiver. I chose this fan because it was the quietest AC fan of this size offered by Parts Express (27 dB). The fan has a cast metal body and appears to be well-made. However, I found that this 27 dB fan was much too noisy to be used in this manner.
Date published: 2012-12-03
Rated 5 out of 5 by from Works exactly as advertised.I have it sitting on the top shelf of my garage refrigerator circulating air inside. The temperature differential between top and bottom shelves of the main compartment dropped from 10 degrees to 3 degrees.
Date published: 2011-08-05
  • 2016-02-14T06:55CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_250-010, PRD, sort_mostRecent
What product can I use for thermostatic control of this fan?
Asked by: tcollins
The product referenced below can be adjusted to control a fan (or fans) according to variations in temperature.
Answered by: RussR
Date published: 2011-03-03
  • 2016-02-14T07:45CST
  • loc_en_US, sid_250-010, PRD, sort_recentQuestionsFirst
