250-026_ALT_0
250-026_ALT_1
Thermocool 110 VAC Muffin Cooling Fan 150 x 50mm Sleeve Bearing 176 CFM
Brand:|Model: G15050HAS|Part # 250-026
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product.
List Price$39.99
You Save46%
$21.60
Buy 10+$19.64
Part # 250-026
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product. Thermocool fans are ideal for use in computer systems, portable CD and DVD players, stereo components, overhead projectors, laptop computers, and many other electronic applications where circulation is a key concern.
Specifications: • Power: 120V AC, 60 Hz • Sleeve bearing • Lead wire connection • 0.40 amps • 2600 RPM • 54dB noise level • 176CFM air flow • Dimensions: 150 mm (H) x 150 mm (W) x 50 mm (D).
  • Operating Voltage110~120 VAC
  • Size150 mm
  • Bearing TypeSleeve Bearing
  • BrandThermocool
  • ModelG15050HAS
  • Part Number250-026
  • UPC656403815507
  • Product CategoryEquipment Cooling
    (1 Reviews)
  • Weight1.95 lbs.
View similar products to the Thermocool 110 VAC Muffin Cooling Fan 150 x 50mm Sleeve Bearing 176 CFM
in the Equipment Cooling product category.
Thermocool 110 VAC Muffin Cooling Fan 150 x 50mm Sleeve Bearing 176 CFM is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Strong FanThis fan fit our application nicely. It did not seem to bog down under load like the fan it replaced. It is quite and certainly moves a lot of air.
Date published: 2014-09-08
  • 2016-02-08T06:33CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_250-026, PRD, sort_mostRecent
