250-024_ALT_0
250-024_ALT_1
Thermocool 110 VAC Muffin Cooling Fan 135 x 38mm Sleeve Bearing 97 CFM
Brand:|Model: G13538HAS|Part # 250-024
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product.
List Price$24.99
You Save51%
$12.30
Buy 10+$11.18
Part # 250-024
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product. Thermocool fans are ideal for use in computer systems, portable CD and DVD players, stereo components, overhead projectors, laptop computers, and many other electronic applications where circulation is a key concern.
Specifications: • Power: 120V AC, 60 Hz • Sleeve bearing • Lead wire connection • 0.34 amps • 2400 RPM • 46dB noise level • 97CFM air flow • Dimensions: 135 mm (H) x 135 mm (W) x 38 mm (D).
  • Operating Voltage110~120 VAC
  • Size135 mm
  • Bearing TypeSleeve Bearing
  • BrandThermocool
  • ModelG13538HAS
  • Part Number250-024
  • UPC656403813381
  • Product CategoryEquipment Cooling
    (1 Reviews)
  • Weight1.25 lbs.
View similar products to the Thermocool 110 VAC Muffin Cooling Fan 135 x 38mm Sleeve Bearing 97 CFM
in the Equipment Cooling product category.
Thermocool 110 VAC Muffin Cooling Fan 135 x 38mm Sleeve Bearing 97 CFM is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Want to move some air? Buy this!I purchase 2 of these to cool and overheating amp. I was using 1 small fan to try to cool a 100 watt amp and it could not keep up when the amp was pushed hard causing the thermal circuit protector to kick in and do its thing. After installing two of these on top of the amp, my problem has been solved. The fans are loud, but once I close the cabinet door and crank it up, the noise is drowned out.
Date published: 2012-07-18
  • 2016-02-09T06:33CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_250-024, PRD, sort_mostRecent
How do I plug this in?
Asked by: JPro
You will have to splice a power cord to the bare wire ends of the fan, then it simply plugs into the wall.
Date published: 2014-06-19
  • 2016-02-09T07:01CST
  • loc_en_US, sid_250-024, PRD, sort_recentQuestionsFirst
