250-018_ALT_0
250-018_ALT_1
Thermocool 110 VAC Muffin Cooling Fan 120 x 38mm Sleeve Bearing 82 CFM
Brand:|Model: G12068HAS|Part # 250-018
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product.
List Price$19.99
You Save47%
$10.50
Buy 10+$9.69
Part # 250-018
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product. Thermocool fans are ideal for use in computer systems, portable CD and DVD players, stereo components, overhead projectors, laptop computers, and many other electronic applications where circulation is a key concern.
Specifications: • Power: 120V AC, 60 Hz • Sleeve bearing • Terminal connection • 0.28 amps • 2600 RPM • 43dB noise level • 82CFM air flow • Dimensions: 120 mm (H) x 120 mm (W) x 38 mm (D).
  • Operating Voltage110~120 VAC
  • Size120 mm
  • Bearing TypeSleeve Bearing
  • BrandThermocool
  • ModelG12068HAS
  • Part Number250-018
  • UPC656403812384
  • Product CategoryEquipment Cooling
    (1 Reviews)
  • Weight1 lbs.
View similar products to the Thermocool 110 VAC Muffin Cooling Fan 120 x 38mm Sleeve Bearing 82 CFM
in the Equipment Cooling product category.
Thermocool 110 VAC Muffin Cooling Fan 120 x 38mm Sleeve Bearing 82 CFM is rated 3.0 out of 5 by 1.
Rated 3 out of 5 by from What? I can't hear you.This is an extremely well made fan and moves a lot of air. But it's so loud. I purchased it to replace a similarly-sized fan that we use to move air through a hallway from a heated space to an unheated space. CFM's were only slightly greater, but the noise level is intolerably greater. However, if noise is not an issue, this is a great buy. It's too cheap to return, so I'll find a use for it someday.
Date published: 2013-05-17
  • 2016-02-12T06:28CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_250-018, PRD, sort_mostRecent
I'm planning on using this fan as a replacement on my son's small air hockey table. How would I hook this thing up so I could plug it into a wall?
Asked by: somedude
All you will need is a power cord like the one below.http://www.parts-express.com/cooling-fan-45-degree-power-cord-6-ft--250-076
Date published: 2015-05-19
  • 2016-02-12T07:07CST
  • loc_en_US, sid_250-018, PRD, sort_recentQuestionsFirst
