Terk Pi-B AM/FM Amplified Antenna
Brand:|Model: PI-B|Part # 210-215
The TERK AM/FM Pi is a compact yet highly powerful antenna that combines cutting-edge design with the latest in technology. Only TERK antennas feature the Gamma Loop™ technology. It reduces the background broadcast noise level, increasing the signal-to-noise ratio for quality radio reception.
List Price$59.99
You Save24%
$45.77
Buy 4+$43.76
Part # 210-215
  • Featuring separate AM and FM antennas in a single housing
  • Patented Non-Coinduction™circuitry to isolate the antennas from one another
  • Easy to install and its unique design blends with most decors
  • Built-in signal amplifier can be adjusted to the optimum level
  • 45 Day Money Back Guarantee
The TERK AM/FM Pi is a compact yet highly powerful antenna that combines cutting-edge design with the latest in technology. Only TERK antennas feature the Gamma Loop™ technology. It reduces the background broadcast noise level, thus increasing the signal-to-noise ratio for higher quality radio reception. Its built-in signal amplifier can be adjusted to the optimum level to either strengthen reception of weaker and distant stations or to avoid over-boosting stronger or closer ones. The Pi was also constructed as two antennas in one, featuring separate AM and FM antennas in a single housing. Its AM loop is movable and swings away from the FM antenna for optimum AM reception. The Pi features TERK’s patented Non-Coinduction™ circuitry to isolate the antennas from one another and eliminate interference. The Pi is easy to install and its unique design blends with most dÉcors. With the emergence of new technology in radio broadcasting, the AM/FM Pi is designed to be digital broadcast radio ready.
Specifications: FM Section: Reception Pattern: Omni-directional • Frequency Range: 88 to 108MHz • Amplifier Gain: 8dB min • Gain Control: 30dB min • FM Output Impedance: 75 Ohm AM Section: • Frequency Range: 540 to 1700 KHz • AM Output Impedance: 300 Ohm, Twin-lead • Dimensions 6" W x 6" H x 2.5" D.
  • BrandTerk
  • ModelPI-B
  • Part Number210-215
  • UPC034405000976
  • Product CategoryAM/FM & HD Radio Antennas
    (2 Reviews)
  • Weight1.6632 lbs.
View similar products to the Terk Pi-B AM/FM Amplified Antenna
in the AM/FM & HD Radio Antennas product category.
