180-336_ALT_0
180-336_ALT_1
180-336_ALT_2
180-336_ALT_3
180-336_ALT_4
180-336_ALT_5
180-336_ALT_6
Terk LF30S Wireless 2.4 GHz Wireless A/V Entertainment Expansion System
Brand:|Model: LF30S|Part # 180-336
The Leapfrog LF-30S is a wireless transmitter/receiver system that eliminates the need or expense of running extra wires from room to room. It gives you the power to control the video source from a second TV location using your remote control.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$99.99
You Save10%
$89.90
Buy 4+$87.75
Part # 180-336
  • Easy plug and play installation
  • Built-in modulator ensures easy connection to any TV
  • Wirelessly transmits audio and video from any A/V source - up to 150’ away
  • IR extender
  • Multiple channel selection for the best possible signal
  • Transmits via 2.4GHz frequency - providing for the clearest signals
The Leapfrog LF-30S is a wireless transmitter/receiver system that eliminates the need or expense of running extra wires from room to room. It gives you the power to control the video source from a second TV location using your remote control. By transmitting across the 2.4 GHz frequency band it gives you the clearest signal - with up to a 150ft range. Its signals penetrates walls, doors, ceilings and floors without any interference. Multiple channel selection allows you to select from four different channels to ensure that you’re receiving the best signal possible. The LF-30S is easy to install requiring no tools. A built-in modulator ensures easy connection to any TV, either new or old. The LF-30S system is even expandable. With the purchase of additional receivers, you can use it with multiple TVs throughout your home.
Specifications: • Transmitter Unit: Video • Input: RCA jack • Audio input: RCA jack •  Transmitter frequency: 2.4 to 2.48GHz • Transmitter level: 107dVuV/meter • Frequency stability: +/-0.005% • Modulation: FM (audio and video) • Channel number: 4@ 18MHz/CH • Power source: 120VAC 60Hz/15VDC • 300mA AC adapter                   • Dimensions: 5-1/2" X 3-3/4" X 1-3/4" IR Emitter Section • Carrier frequency: 38KHz • Distance between emitter & detect: 4.5 meter by 38KHz • Half angle: +/- 33(degree) • Receiver frequency: 433.92 MHz • 32IR output: 3.5 earphone jack • Receiver Unit: Video • Output: RCA jack • Audio output: RCA jack • Receiver frequency: 2.4 to 2.48GHz • Frequency stability: +/-0.005% • Channel number: 4@ 18MHz/CH • Receiver sensitivity: <= -45dBm • RF output level: 60dBuV(min.) NTSC Ch.3/4 (switchable)     • Power source: 120VAC 60Hz/15VDC, 300mA AC adapter • Dimensions: 5.5" X 3.75" X 1.75" • IR Receiver Section: Carrier frequency: 38KHz • Half angle: +/- 45(degree)   • Receiver distance: 5 meters by 38KHz • Transmitter frequency: 433.92 MHz • Frequency stability: +/- 500KHz • Transmit level: 0-10dBm.
  • Audio Input/OutputL/R Analog
  • Video Input/OutputComposite
  • BrandTerk
  • ModelLF30S
  • Part Number180-336
  • UPC034405000785
  • Product CategoryAudio / Video Distribution
    (6 Reviews)
  • Weight3.6 lbs.
View similar products to the Terk LF30S Wireless 2.4 GHz Wireless A/V Entertainment Expansion System
in the Audio / Video Distribution product category.
