Tenergy World Travel Outlet Adapter and Dual USB Charger
Brand:|Part # 142-0005
The Tenergy world travel outlet adapter and dual USB port charger replenishes the power of your USB devices on any wall outlet, wherever you are.
List Price$19.99
You Save25%
Buy 4+$12.78
Part # 142-0005
  • Adapts your electronic device's switching power supply plug to different outlets
  • Four different inputs and outputs cover over 150 countries
  • Includes a dual USB port charger
  • Does not act as a voltage converter, your device must work on the connected voltage standard
The Tenergy world travel outlet adapter and USB port AC charger allows to connect any ungrounded 2-prong electronic device to any standard wall outlet worldwide in over 150 countries, as well as charging two devices simultaneously! Four input jacks and four selectable, locking plugs—one for USA and Japan, one for Australia and China, one for the UK, and one for Europe—quick-change outlet standards in seconds. There is also an extra compartment for spare fuses, with one included.
Use the dual port USB AC charger independently from the adapter, and add the convenience of charging your electronic device anywhere you are. Compatible with almost any device that charges over USB: iPhones, iPods, Android and Windows Phone smartphones, as well as being able to trickle charge tablets.
Note: This adapter does not act as a voltage-converting device. Your device must support the local voltage to which you are connecting. Many modern power supplies and devices are built for 90 to 240 VAC operation. Please consult your device's manual prior to use with this adapter.
Specifications: Dual USB charger: • Power input: 100-240 VAC 50-60 Hz • Power output: 5.0 VDC, 1A (per channel). Power adapter: • Max power rating: 220 VAC: 1,300 watts, 110 VAC: 650 watts.
  • DC Output Voltage5V
  • Current Capacity1000 mA
  • Plug SizeUSB
  • Input Voltage100~240 VAC
  • BrandTenergy
  • Part Number142-0005
  • UPC844949016599
  • Product CategoryCell Phone / Tablet Chargers & Cables
  • Weight0.4700 lbs.
View similar products to the Tenergy World Travel Outlet Adapter and Dual USB Charger
in the Cell Phone / Tablet Chargers & Cables product category.
