CLEARANCE
Tenergy 10516-0 Propel Industrial Grade Sub C Cell Rechargea
Tenergy Propel Industrial Grade Sub C Cell Rechargeable High Drain 10C NiMH Battery 3000mAh Flat Top
Brand:|Part # 142-0226
Looking for the ideal battery for your high-drain electronic device? Tenergy has the answer with their industrial grade Sub C cell rechargeable NiMH battery. Compatible with all NiMH chargers that support C batteries, Tenergy's Industrial line features an advanced design that lasts up to twice as long as other rechargeable batteries. The 3000 mAh capacity offers robust performance under load.
List Price$6.99
You Save46%
$3.77
Buy 10+$3.60
Part # 142-0226
  • Advanced NiMH technology for twice the life of other rechargeables
  • Easy operation with no memory effect like NiCd batteries, can be charged anytime
  • Higher current capabilities for high drain applications
  • IEC tested for capacity and a minimum 500 cycle life
  • Able to be rapid charged and saves you money
Tenergy industrial grade Sub C cell rechargeable NiMH batteries can be cycled, from completely dead, to fully charged, a minimum of 1000 times, which adds up to big savings over throwaway alkaline batteries. Up to 30 amps makes these batteries perfect for toys, power tools, and electrical guns. The flat top makes this battery ideal for pack building applications. (Charger not included).
Specifications: • Voltage: 1.2 V • Maximum capacity: 3000 mAh • Maximum current: 1 C • Charging current: Standard rate: 300 mA for 15 hours, rapid rate: 3000mA for 1.5 hours • Dimensions: 43 mm H x 23 mm D • Weight per cell 51 g.
  • SizeSub-C, 1/2SC, 4/5SC
  • TechnologyNiMH Rechargeable
  • Voltage1.2V
  • BrandTenergy
  • Part Number142-0226
  • UPC848864017419
  • Product CategoryIndustrial Rechargeable Battery Cells
  • Weight0.1130 lbs.
View similar products to the Tenergy Propel Industrial Grade Sub C Cell Rechargeable High Drain 10C NiMH Battery 3000mAh Flat Top
in the Industrial Rechargeable Battery Cells product category.
