Tenergy 10302-0 Industrial Grade AA Cell Rechargeable High D
Tenergy Industrial Grade AA Cell Rechargeable High Drain 10C NiMH Battery 1800mAh Flat Top
Brand:|Part # 142-0208
Looking for the ideal battery for your high-drain electronic device? Tenergy has the answer with their industrial grade AA rechargeable NiMH battery. Compatible with all NiMH chargers that support AA batteries, Tenergy's Industrial line features an advanced design that lasts up to twice as long as other rechargeable batteries. The 1800 mAh capacity offers robust performance under load.
  • Advanced NiMH technology for twice the life of other rechargeables
  • Easy operation with no memory effect like NiCd batteries, can be charged anytime
  • Higher current capabilities for high drain applications
  • IEC tested for capacity and a minimum 500 cycle life
  • Able to be rapid charged and saves you money
Tenergy industrial grade AA rechargeable NiMH batteries can be cycled, from completely dead, to fully charged, a minimum of 1000 times, which adds up to big savings over throwaway alkaline batteries. These batteries are perfect for mini RC airplane power packs and cordless phones. The flat top makes this battery perfect for pack building applications. (Charger not included).
Specifications: • Nominal Voltage: 1.2 V • Maximum discharge: 16 A, standard discharge: 1.0 C • Maximum discharge current: 10 C • Charging current: Standard rate: 160 mA for 16 hours, rapid rate: 1600 mA for 1.2 hours • Dimensions: 49.5 mm H x 14.5 mm D • Weight per cell 26 g.
  • SizeAA
  • TechnologyNiMH
  • Voltage1.2V
  • BrandTenergy
  • Part Number142-0208
  • UPC848864017310
  • Product CategoryIndustrial Rechargeable Battery Cells
  • Weight0.0600 lbs.
View similar products to the Tenergy Industrial Grade AA Cell Rechargeable High Drain 10C NiMH Battery 1800mAh Flat Top
in the Industrial Rechargeable Battery Cells product category.
