Tenergy 10702-0 Industrial Grade 4/3A 17670 Cell Rechargeabl
Tenergy Industrial Grade 4/3A 17670 Cell Rechargeable NiMH Battery 3800mAh Flat Top
Brand:|Part # 142-0218
Looking for the ideal battery for your high-drain electronic device? Tenergy has the answer with their industrial grade 4/3A rechargeable NiMH battery. Compatible with all NiMH chargers that support single A batteries, Tenergy's Industrial line features an advanced design that lasts up to twice as long as other rechargeable batteries. The 3800 mAh capacity offers robust performance under load.
  • Advanced NiMH technology for twice the life of other rechargeables
  • Easy operation with no memory effect like NiCd batteries, can be charged anytime
  • Higher current capabilities for high drain applications
  • IEC tested for capacity and a minimum 500 cycle life
  • Able to be rapid charged and saves you money
Tenergy industrial grade 4/3A rechargeable NiMH batteries can be cycled, from completely dead, to fully charged, a minimum of 1000 times, which adds up to big savings over throwaway alkaline batteries. These batteries are perfect for power tools, portable emergency power sources, and medical applications. The flat top makes this battery perfect for pack building applications. (Charger not included).
Specifications: • Nominal Voltage: 1.2 V • Maximum discharge: 7Amp, standard discharge: 3.8Amp • Charging current: Standard rate: 250 mA for 16 hours, rapid rate: 1250mA for 2.4 hours • Dimensions: 17.5 mm H x 67 mm D • Weight per cell 50 g.
  • SizeA, 2/3AF, 4/3A, 4/3AF, 4/5A
  • TechnologyNiMH
  • Voltage1.2V
  • BrandTenergy
  • Part Number142-0218
  • UPC848864017259
  • Product CategoryIndustrial Rechargeable Battery Cells
  • Weight0.1140 lbs.
View similar products to the Tenergy Industrial Grade 4/3A 17670 Cell Rechargeable NiMH Battery 3800mAh Flat Top
in the Industrial Rechargeable Battery Cells product category.
