310-500_ALT_0
310-500_ALT_1
310-500_ALT_2
310-500_ALT_3
TeiNuro 2.1 Powered Multimedia System MP3/USB/SD Card Input
Brand:|Part # 310-500
TeiNuro's powered 2.1 multimedia system will make you a believer in just one listen. Computer speakers have no right to sound this good!
Part # 310-500
  • Plays MP3 files off of USB and SD card storage
  • Rich, powerful bass with room-filling sound
  • Built-in amplifier with tone controls
Computer speakers have no right to sound this good! TeiNuro's powered 2.1 multimedia system will make you a believer in just one listen. Already have your music files loaded on a USB thumb drive or SD card?  Simply plug your storage device into the rear USB port or SD slot for instant playback!  A 3.5 mm input allows for quick connection to PCs, laptops, Apple® products, and most smartphone headphone outputs, for streaming Pandora® Radio or playing from the internal memory.
Passive chrome 1/2" Mylar® dome acoustic radiators are used to recreate crystal clear highs with an amazing off-axis power response. Magnetically shielded 2-3/4" midranges designed around unique paper cones with treated foam surrounds for unparalleled quickness and transient response. The small micro-bookshelf size not only saves desk space, it is essential for creating sound that follows you around.
Believe that subwoofers need to be large for good output and deep bass? Think again... Two 3" bass drivers with butyl rubber surround are paired together in a diminutive bass-reflex enclosure for surprisingly deep lows that are both articulate and punchy, while distracting vent noise is kept at bay through the use of a flared port. The subwoofer acts as anchor of this system, with the 2.1 amplifier housed within its chassis. Volume and tone controls are built onto the face for adjustability when using USB or SD storage solutions, or you can set-and-forget using the volume control built into your computer software. LIMITED AVAILABILITY.
Amplifier specifications: • Satellite power output: 2 x 3 watts RMS • Woofer power output: 6 watts RMS • Amplifier distortion: 0.15% (1W @ 1 kHz).
Satellite specifications: • Frequency response: 200-18,000 Hz • Midrange: 2-3/4" paper-cone with treated foam surround • High frequency acoustic radiator: 1/2" Mylar® dome • Dimensions: 5.9" H x 3.46" W x 3.78" D • 1.5 meter connection cable.
Base unit/woofer specifications: • Frequency response: 50-200 Hz • Woofers: 2 x 3" paper cone with butyl rubber surround • Dimensions: 5.9" H x 9.06" W x 8.11" D.
  • Special FeaturesPowered
  • Woofer Diameter3"
  • Configuration2.1 System
  • ColorBlack
  • BrandTeiNuro
  • Part Number310-500
  • UPC844632092763
  • Product CategoryStereo Shelf Systems
    (82 Reviews)
  • Weight8.25 lbs.
View similar products to the TeiNuro 2.1 Powered Multimedia System MP3/USB/SD Card Input
in the Stereo Shelf Systems product category.
Videos
