Tectonic Elements TEBM65C20F-8 3-1/2" BMR Full-Range Speaker 8 Ohm
Brand:|Model: TEBM65C20F-8|Part # 297-2156
For audio applications that require extended frequency response, and superior off-axis response in a small form factor, choose the Tectonic Elements TEBM65C20F-8 3-1/2" full-range transducer. Nearly all of the audio in the pass band of the driver is available up to 100° off-axis.
$14.39
Buy 4+$13.35
Part # 297-2156
  • Amazing off-axis frequency response
  • Small form factor with decent Xmax
  • Perfect for modern speaker applications such as soundbars
Tectonic Elements TEBM65C20F-8 Balanced-Mode Radiator (BMR) features extended frequency response and wide dispersion compared to that of a conventional drive unit. It combines the benefits of Tectonic Elements bending-wave technology and pistonic modes of operation. It is ideally suited for compact audio applications that require a full-range, high performance acoustic solution such as a soundbar. An advanced ferrite-based motor is combined with special cone dampers to ensure a small size that outperforms conventional drivers, especially in off-axis performance.
  • Nominal Diameter3-1/2"
  • Power Handling (RMS)20 Watts
  • Power Handling (max)40 Watts
  • Impedance8 ohms
  • Frequency Response80 to 20,000 Hz
  • Sensitivity81 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)86 Hz
  • DC Resistance (Re)7.2 ohms
  • Voice Coil Inductance (Le)0.055 mH
  • Mechanical Q (Qms)4.9
  • Electromagnetic Q (Qes)1.09
  • Total Q (Qts)0.89
  • Compliance Equivalent Volume (Vas)0.04 ft.³
  • Mechanical Compliance of Suspension (Cms)0.65 mm/N
  • BL Product (BL)4.33 Tm
  • Diaphragm Mass Inc. Airload (Mms)5.25g
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Cone MaterialPaper
  • Magnet MaterialFerrite
  • Overall Outside Diameter4.25"
  • Baffle Cutout Diameter3.4"
  • Depth1.88"
  • # Mounting Holes6
  • Sealed Volume0.1 ft.³
  • Sealed F384 Hz
  • Vented Volume0.2 ft.³
  • Vented F350 Hz
  • BrandTectonic Elements
  • ModelTEBM65C20F-8
  • Part Number297-2156
  • UPC844632098789
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (26 Reviews)
  • Weight1.6500 lbs.
View similar products to the Tectonic Elements TEBM65C20F-8 3-1/2" BMR Full-Range Speaker 8 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
