Clearance Item
297-2159_ALT_0
Tectonic Elements HIBM130H10-8/LP 1" x 5" HARP BMR Speaker 8 Ohm
Brand:| Model: HIBM130H10-8/LP
Tectonic Elements HIBM130H10-8/LP features a relatively flat frequency response from 200 Hz all the way up to 20,000 Hz, superior off-axis response (when compared to traditional drivers), and a super small footprint for custom audio applications.
  • High Aspect Ratio Panel (HARP) transducer
  • Dual neodymium magnet motors
  • Amazing off-axis frequency response
  • Small, compact size
  • Great for use in line arrays
297-2159
Weight: 0.2 lbs.
The HIBM130H10-8/LP High Aspect Ratio Panel Balanced Mode Radiator (HARP BMR) is an audio drive unit with an extended frequency response and wide dispersion compared to that of a conventional drive unit. It combines the benefits of Tectonic's bending-wave technology and pistonic  modes of operation. The low-profile form-factor is ideally suited for thin, flat-panel TV audio applications that require a fullrange, high performance acoustic solution. Tectonic Elements HIBM130H10-8/LP is also great for us in line array speakers.
  • Nominal Diameter1" x 5"
  • Power Handling (RMS)10 Watts
  • Power Handling (max)15 Watts
  • Impedance8 ohms
  • Frequency Response100 to 20,000 Hz
  • Sensitivity78 dB 1W/1m
  • Voice Coil Diameter0.65"
  • Resonant Frequency (Fs)173 Hz
  • DC Resistance (Re)8 ohms
  • Voice Coil Inductance (Le)0.1 mH
  • Mechanical Q (Qms)5.2
  • Electromagnetic Q (Qes)1.8
  • Total Q (Qts)1.34
  • Compliance Equivalent Volume (Vas)0.01 ft.³
  • Mechanical Compliance of Suspension (Cms)0.4 mm/N
  • BL Product (BL)3.4 Tm
  • Diaphragm Mass Inc. Airload (Mms)2.7g
  • Maximum Linear Excursion (Xmax)5.6 mm
  • Surface Area of Cone (Sd)25.2 cm²
  • Cone MaterialPaper
  • Overall Outside Diameter5.16 x 1.14"
  • Baffle Cutout Diameter4.84 x 0.83"
  • Depth0.82"
  • # Mounting Holes4
  • BrandTectonic Elements
  • ModelHIBM130H10-8/LP
  • Part Number297-2159
  • UPC844632098802
  • Product CategoryMini Speakers
    (1 Reviews)
  • Weight0.2 lbs.
View similar products to the Tectonic Elements HIBM130H10-8/LP 1" x 5" HARP BMR Speaker 8 Ohm
in the Mini Speakers product category.
Customer projects that include: Tectonic Elements HIBM130H10-8/LP 1" x 5" HARP BMR Speaker 8 Ohm
