Tectonic Elements 25mm SoundPax Exciter Turns Virtually Anything Into A Speaker
Brand:|Part # 309-149
Turn nearly any surface into a high fidelity speaker with Tectonic Elements SoundPax exciters.
  • Turn any solid surface into a great sounding speaker system
  • Create a completely hidden surround sound system
  • Pre-attached adhesive pads for secure and fast placement
  • Wideband frequency response (dependent on attached material)
  • Pre-attached 6" speaker wires
Tectonic Elements SoundPAX exciters turn virtually any solid object into a speaker by vibrating it at speeds of up to 20,000 cycles per second. The vibrations modulate the air, which is then decoded by the brain as sound. We've tested and placed exciters on nearly everything you can imagine; under a desk, in an overhead cabinet, behind picture frames, inside cans, behind paper plates, inside binders, cardboard, scraps of wood and even the box they came in! Test the limits of your imagination.
Each stick-on SoundPAX exciter is designed for a wide frequency response and great sensitivity. A 6" speaker wire harness is pre-attached with male bullet terminals and an inline polyswitch protects the SoundPAX from overpower conditions. Strong adhesive pads affix to nearly any solid surface for secure, long-lasting playback. Sold individually.
Specifications: • Power handling: 5W RMS • Impedance: 8 ohms • VCdia: 1" • Spring-loaded push terminals • Dimensions: 3.66" dia. x 0.75" H.
  • Impedance8 ohms
  • Power Handling (RMS)5 Watts
  • BrandTectonic Elements
  • Part Number309-149
  • UPC848864002989
  • Product CategoryExciters & Tactile Transducers
    (6 Reviews)
  • Weight0.135 lbs.
View similar products to the Tectonic Elements 25mm SoundPax Exciter Turns Virtually Anything Into A Speaker
in the Exciters & Tactile Transducers product category.
