082-346_ALT_0
Techflex 3/8" Expandable Sleeving 25 ft. Neon Yellow
Brand:|Model: PT2.5NY25-C|Part # 082-346
Flexo is a strong expandable sleeving that not only provides a professional look but also protects cables, wires and hoses from abrasion, cuts and ultra-violet light.
  • Professional look for custom cable assemblies
  • Bundles cables and organizes wires
  • Easy to install, lightweight and flexible
  • Abrasion, chemical and U/V resistant
  • Wide operating temperature
  • Available in a variety of colors and sizes
Techflex Flexo is a strong expandable sleeving that not only provides a professional look but also protects cables, wires and hoses from abrasion, cuts and ultra-violet light. Due to its expandable nature, the braiding will easily slip over large connectors and then "form-fit" over cables for quick and easy installations. Because it is available in a variety of colors and sizes, it can be used to "color code" wires for easy identification. It is braided from .010" monofilament polyester yarn that can withstand temperature extremes from -103° F to +257° F, making it perfect for automotive applications. Flexo can be terminated using electrical tape, wire ties or heat shrink. For a professional look, and to slide over large connectors, we recommend using our 3-to-1 Ratio heat shrink which is also available in a variety of colors and sizes. Braiding must be cut with a hot knife to prevent unraveling and has a melting temperature of +446° F. Sold in 25 ft. lengths.
Specifications: • Size I.D.: 3/8" • Size Range (min~max): 3/16"~5/8" • Color: Neon Yellow.
  • Sleeving TypeExpandable
  • ColorNeon Yellow
  • Length25 ft.
  • Nominal I.D.0.375"
  • BrandTechflex
  • ModelPT2.5NY25-C
  • Part Number082-346
  • UPC738854005512
  • Product CategoryExpandable Braided Sleeving
  • Weight0.21 lbs.
View similar products to the Techflex 3/8" Expandable Sleeving 25 ft. Neon Yellow
in the Expandable Braided Sleeving product category.
