293-682_ALT_0
293-682_ALT_1
293-682_ALT_2
293-682_ALT_3
293-682_ALT_4
293-682_ALT_5
293-682_ALT_6
TC Sounds VMP 15" Passive Radiator
Brand:|Model: 3240-00|Part # 293-682
The VMP 15" passive radiator is designed to allow up to 3.5" peak-to-peak excursion and to be easily adjustable, so that you can get the most out of your small enclosure passive radiator design.
Part # 293-682
  • Adjustable moving mass
  • Very high excursion limits of 3.5" peak-to-peak
  • Same cosmetics as the Axis and LMS-R
The VMP 15" passive radiator is designed to allow up to 3.5" peak-to-peak excursion and to be easily adjustable, so that you can get the most out of your small enclosure passive radiator design. Designed specifically to be used in incredibly small home and car audio subwoofers, where a port simply won't work!
Specifications: • Fs: 28.8 Hz • Vas: 2.30 cu. ft. • Qms: 7.00 • Cms: 0.063 mm/N • Mms: 540 g • Sd: 855.27 sq. cm. • Dimensions: Overall diameter: 15.60", Cutout diameter: 14.02", Depth: 7.00".
View All TC Sounds Subwoofers
  • Nominal Diameter15"
  • BrandTC Sounds
  • Model3240-00
  • Part Number293-682
  • UPC844632083068
  • Product CategoryPassive Radiators
    (1 Reviews)
  • Weight17 lbs.
View similar products to the TC Sounds VMP 15" Passive Radiator
in the Passive Radiators product category.
Videos
