293-680_ALT_0
293-680_ALT_1
293-680_ALT_2
293-680_ALT_3
293-680_ALT_4
293-680_ALT_6
TC Sounds VMP 12" Passive Radiator
Brand:|Model: 3239-00|Part # 293-680
The VMP 12" passive radiator is designed to allow up to 3.5" peak-to-peak excursion and to be easily adjustable, so that you can get the most out of your small enclosure passive radiator design.
Part # 293-680
  • Adjustable moving mass
  • Very high excursion limits of 3.5" peak-to-peak
  • Same cosmetics as the Axis and LMS-R
The VMP 12" passive radiator is designed to allow up to 3.5" peak-to-peak excursion and to be easily adjustable, so that you can get the most out of your small enclosure passive radiator design. Designed specifically to be used in incredibly small home and car audio subwoofers, where a port simply won't work!
Specifications: • Fs: 30.7 Hz • Vas: 1.01 cu. ft. • Qms: 7.00 • Cms: 0.85 mm/N • Mms: 390 g • Sd: 480.86 sq. cm. • Dimensions: Overall diameter: 12.60", Cutout diameter: 11.16", Depth: 6.75".
View All TC Sounds Subwoofers
  • Nominal Diameter12"
  • BrandTC Sounds
  • Model3239-00
  • Part Number293-680
  • UPC844632083051
  • Product CategoryPassive Radiators
  • Weight12.2 lbs.
View similar products to the TC Sounds VMP 12" Passive Radiator
in the Passive Radiators product category.
Videos
Part # 293-680
