293-674_ALT_0
293-674_ALT_1
293-674_ALT_2
293-674_ALT_3
TC Sounds Pro 5100 18" Neo Subwoofer Driver
Brand:|Model: Pro 5100|Part # 293-674
Capable of very high excursion and high efficiency, the Pro 5100 driver indeed redefines the state-of-the-art in Professional Audio.
  • High-temperature low eddy-current stainless steel voicecoil former
  • 2+2 ohm dual voicecoil 4-layer flatwound Aluminum wire, 4" diameter voicecoil
  • 10" linear dual spider suspension with large integral lead-wires
  • 3" long segmented radial NdFeB motor assembly, for low mass and very high BL
  • FEA designed 3-roll cloth surround for greater than 2.5" peak-to-peak travel
  • Field-replaceable top assembly system
  • Large anti-flux-modulation shorting ring
Capable of very high excursion and high efficiency, the Pro 5100 driver indeed redefines the state-of-the-art in Professional Audio. The highest power underhung radial Neodymium motor ever made is coupled with an acrylic foam fiberglass sandwich cone and a 4-layer flatwound Aluminum voice coil that surpasses the thermal durability of egewound voice coils. The field-replaceable top assembly allows for easy servicing when you are on tour. In addition, an Aura 1808™ compatible top assembly is available as well, to bolt onto your old Aura motor.
TC Sounds Pro 5100 18" Neo Subwoofer Driver includes the following items:
Qty Part # Item
1293-676TC Sounds Pro 5100 18" Basket Assembly
1293-677TC Sounds Pro 5100 Motor Assembly
  • Nominal Diameter18"
  • Power Handling (RMS)1,000 Watts
  • Power Handling (max)2000 Watts
  • Impedance2+2 ohms
  • Frequency Response15 to 150 Hz
  • Sensitivity94.5 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)26.5 Hz
  • DC Resistance (Re)3.02 ohms
  • Voice Coil Inductance (Le)1.96 mH
  • Mechanical Q (Qms)6.9
  • Electromagnetic Q (Qes)0.25
  • Total Q (Qts)0.24
  • Compliance Equivalent Volume (Vas)8.88 ft.³
  • Mechanical Compliance of Suspension (Cms)1.13 mm/N
  • BL Product (BL)23.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)287.1g
  • Maximum Linear Excursion (Xmax)19.05 mm
  • Cone MaterialFiberglass
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerStainless Steel
  • Magnet MaterialNeodymium
  • Overall Outside Diameter18.52"
  • Baffle Cutout Diameter16.83"
  • Depth11.27"
  • # Mounting Holes8
  • Sealed Volume0.77 ft.³
  • Sealed F391 Hz
  • Vented Volume1.72 ft.³
  • Vented F359 Hz
  • BrandTC Sounds
  • ModelPro 5100
  • Part Number293-674
  • UPC844632083020
    (4 Reviews)
  • Weight53.4 lbs.
View similar products to the TC Sounds Pro 5100 18" Neo Subwoofer Driver
Videos
