293-657_ALT_0
293-657_ALT_1
293-657_ALT_2
TC Sounds Epic 8" DVC 500 Watt RMS Subwoofer
Brand:|Model: 3429-00|Part # 293-657
A TC Sounds EPIC 8" subwoofer driver is powered by an oversized, optimized low-distortion magnet structure, and will work perfectly as the cornerstone of any mobile audio, home theater, or music playback speaker system.
Part # 293-657
  • 2 + 2 ohm dual voice coil extracts maximum watts from your amp
  • Single dish aircraft-grade aluminum alloy cone
  • 140 oz. magnet motor structure provides incredible motor strength
  • Anti-flux-modulation shorting ring reduces distortion
  • Extra-large linear spider suspension with integral lead-wires
  • Large 1" symmetrical XBR rubber surround for beyond 2" peak-to-peak travel
  • High-temperature low eddy current stainless steel voice coil former
The EPIC 8" subwoofer follows the TC Sounds world-class displacement and low distortion performance guarantee: be lighter, smaller, and ultimately more affordable. Even when driven by as little as 300 watts, an EPIC 8" will create impressive volumes of low-distortion sub-bass – connect it to twice that much power and it will really come alive! An EPIC 8" subwoofer driver is powered by an oversized, optimized low-distortion magnet structure, and will work perfectly as the cornerstone of any mobile audio, home theater, or music playback speaker system.
  • Nominal Diameter8"
  • Power Handling (RMS)500 Watts
  • Impedance2+2 ohms
  • Sensitivity81.2 dB 1W/1m
  • Voice Coil Diameter2"
  • Magnet Weight140 oz.
  • Resonant Frequency (Fs)24 Hz
  • DC Resistance (Re)3.72 ohms
  • Voice Coil Inductance (Le)2.31 mH
  • Mechanical Q (Qms)7.2
  • Electromagnetic Q (Qes)0.26
  • Total Q (Qts)0.25
  • Compliance Equivalent Volume (Vas)0.57 ft.³
  • Mechanical Compliance of Suspension (Cms)0.32 mm/N
  • BL Product (BL)15.2 Tm
  • Diaphragm Mass Inc. Airload (Mms)108g
  • Maximum Linear Excursion (Xmax)18.1 mm
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerStainless Steel
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.4"
  • Baffle Cutout Diameter7.4"
  • Depth6.1"
  • # Mounting Holes6
  • Sealed Volume0.44 ft.³
  • Sealed F356 Hz
  • Vented Volume1.35 ft.³
  • Vented F330 Hz
  • BrandTC Sounds
  • Model3429-00
  • Part Number293-657
  • UPC844632088179
  • Product CategoryCar Subwoofer Speakers
    (13 Reviews)
  • Weight19.55 lbs.
View similar products to the TC Sounds Epic 8" DVC 500 Watt RMS Subwoofer
in the Car Subwoofer Speakers product category.
Videos
