293-638_ALT_0
293-638_ALT_1
293-638_ALT_2
293-638_ALT_3
TC Sounds Axis 12Q1 12" Quad VC Subwoofer
Brand:|Part # 293-638
Unleash your music with room to spare with the Axis 12Q1 12" subwoofer. The AXIS has a 40+ pound motor, flat-wound 8-layer conductor voice coil on a triple reinforced stainless steel former.
Part # 293-638
  • High-temperature low eddy-current stainless steel voicecoil former
  • Quad 1.2 ohm voicecoil using 8-layer flatwound Aluminum wire
  • Extra-tall gap for higher BL and additional power-handling
  • 10" linear spider suspension with large integral lead-wires
  • 225 oz. magnet motor structure
  • Patent-pending XBR tall profile surround for 3" peak-to-peak travel
  • Field-replaceable top assembly system
Unleash your music with room to spare with the Axis 12Q1 12" subwoofer. The AXIS is designed with high motor force, long excursion and very high power handling to provide loud deep bass in the mobile environment, or any environment where small enclosure size and ultra-high SPL are required. The AXIS has a 40+ pound motor, flat-wound 8-layer conductor voice coil on a triple reinforced stainless steel former; it works harder so you don't have to give up half your car to a large subwoofer box.
Note: All specifications are with voice coils connected in series.
TC Sounds Axis 12Q1 12" Quad VC Subwoofer includes the following items:
Qty Part # Item
1293-640TC Sounds Axis 12Q1T 12" Basket Assembly
1293-645TC Sounds Axis Motor Assembly
  • Nominal Diameter12"
  • Power Handling (RMS)1,000 Watts
  • Power Handling (max)4000 Watts
  • Impedance1+1+1+1 ohms
  • Frequency Response15 to 150 Hz
  • Sensitivity85.4 dB 1W/1m
  • Voice Coil Diameter3"
  • Magnet Weight225 oz.
  • Resonant Frequency (Fs)27.8 Hz
  • DC Resistance (Re)4.74 ohms
  • Voice Coil Inductance (Le)6.09 mH
  • Mechanical Q (Qms)6.3
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)1.41 ft.³
  • Mechanical Compliance of Suspension (Cms)0.12 mm/N
  • BL Product (BL)24.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)279.6g
  • Maximum Linear Excursion (Xmax)16.51 mm
  • Cone MaterialAluminum
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerStainless Steel
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.6"
  • Baffle Cutout Diameter11.2"
  • Depth7.8"
  • # Mounting Holes8
  • Sealed Volume0.26 ft.³
  • Sealed F368 Hz
  • Vented Volume0.69 ft.³
  • Vented F340 Hz
  • BrandTC Sounds
  • Part Number293-638
  • UPC844632082900
    (1 Reviews)
  • Weight48.4 lbs.
View similar products to the TC Sounds Axis 12Q1 12" Quad VC Subwoofer
Videos
