Tang Band WT-1427G 10" Neo Subwoofer
Brand:|Model: WT-1427G|Part # 264-862
This unique subwoofer features a low profile (3-3/16"), long throw design.
List Price$161.75
You Save23%
Buy 4+$118.20
Part # 264-862
  • Low-profile (3-3/16") design
  • Large neodymium magnet
  • 9.5 mm Xmax
This unique subwoofer features a low profile (3-3/16"), long throw design, making it one of the few 10" subwoofers which can be mounted in-wall. This is made possible by a strong neodymium magnet assembly and large voice coil. When depth is an issue and bass is a must, look no further than this a one-of-a-kind, high quality subwoofer.
  • Nominal Diameter10"
  • Power Handling (RMS)120 Watts
  • Power Handling (max)240 Watts
  • Impedance4 ohms
  • Frequency Response25 to 400 Hz
  • Sensitivity85 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Resonant Frequency (Fs)25 Hz
  • DC Resistance (Re)3.2 ohms
  • Voice Coil Inductance (Le)0.69 mH
  • Mechanical Q (Qms)3.42
  • Electromagnetic Q (Qes)0.31
  • Total Q (Qts)0.29
  • Compliance Equivalent Volume (Vas)1.35 ft.³
  • Mechanical Compliance of Suspension (Cms)0.22 mm/N
  • BL Product (BL)17.35 Tm
  • Diaphragm Mass Inc. Airload (Mms)189.58g
  • Maximum Linear Excursion (Xmax)9.5 mm
  • Surface Area of Cone (Sd)350 cm²
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter10.1"
  • Baffle Cutout Diameter9.25"
  • Depth3.1875"
  • # Mounting Holes8
  • Sealed Volume0.14 ft.³
  • Sealed F3137 Hz
  • Vented Volume0.32 ft.³
  • Vented F388 Hz
  • BrandTang Band
  • ModelWT-1427G
  • Part Number264-862
  • UPC844632057922
    (21 Reviews)
  • Weight4.9 lbs.
View similar products to the Tang Band WT-1427G 10" Neo Subwoofer
